(solved) use enable RX TX GPios for esp01S 8266
riker1
#1 Post by riker1 » 29 Jan 2019, 11:38
how can i select GPIO 1 and 3 (RX TX) for a switch.
Need this for ESP01 controlling relais.
Do not need serial but need 4 Gpios...
Thanks Thomas
Using latest firmware a the moment
Can this be enabled in Hardware section?
Wiki
Re: use enable RX TX GPios for esp01S 8266
#2 Post by Wiki » 30 Jan 2019, 11:43
Just go to Tools/Advanced and disable the serial port, so you will have the GPIO1 and GPIO3 available for your own application.
pi@raspberrypi:~ $ man woman
No manual entry for woman
pi@raspberrypi:~ $
riker1
#3 Post by riker1 » 30 Jan 2019, 11:49
Ah
perfect. will check this
that would be great
riker1
#4 Post by riker1 » 30 Jan 2019, 18:54
that solved it. nice coonfiguration. perfect
thanks
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 16 guests
