how can i select GPIO 1 and 3 (RX TX) for a switch.
Need this for ESP01 controlling relais.
Do not need serial but need 4 Gpios...
Thanks Thomas
Using latest firmware a the moment
Can this be enabled in Hardware section?
(solved) use enable RX TX GPios for esp01S 8266
Re: use enable RX TX GPios for esp01S 8266
Just go to Tools/Advanced and disable the serial port, so you will have the GPIO1 and GPIO3 available for your own application.
pi@raspberrypi:~ $ man woman
No manual entry for woman
pi@raspberrypi:~ $
Ah
perfect. will check this
that would be great
that would be great
that solved it. nice coonfiguration. perfect
thanks
thanks
Users browsing this forum: Bing [Bot] and 138 guests
