I want to send information about temperature, humidity and pressure to Fibaro, which requires authorization. I need to do it cyclically in separate URL calls because I want to do this in to a separate Virtual Device: 1. VD temperature 2. VD humidity, 3. VD pressure
Currently I am sending these parameters to one virtual device. Example below.
I use for this Generic HTTP:
Controller User: loginToFibaro
Controller Password: passwordToFibaro
Controller Publish: api/callAction?deviceID=199&name=setProperty&arg1=ui.temp1.value&arg2=Temp:%val1%,%20Hum:%20%val2%%20,%20press:%20%val3%
I think I should use rules and sendtohttp but how to send SendToHTTP with authorisation?
SendToHTTP IPfibaro,80,/api/callAction?deviceID=200&name=setProperty&arg1=ui.temp.value&arg2=%val1%
SendToHTTP IPfibaro,80,/api/callAction?deviceID=201&name=setProperty&arg1=ui.hum.value&arg2=%val2%
SendToHTTP IPfibaro,80,/api/callAction?deviceID=202&name=setProperty&arg1=ui.press.value&arg2=%val3%
ESP Easy to Fibaro
Re: ESP Easy to Fibaro
Hi, i want to connect ESPEasy temp/humidity sensor to fibaro can you please write how did you setup config on the fibaro Virtual Device that it can display the parameters ?
Can you use it to create scenes based on the parameters read from ESP Sensors ?
supporting photos:
https://drive.google.com/file/d/1h4KSjU ... sp=sharing
https://drive.google.com/file/d/1aZrHkV ... sp=sharing
https://drive.google.com/file/d/1y1slKw ... sp=sharing
https://drive.google.com/file/d/1YjB1xW ... sp=sharing
Controller Publish:
DS18b20 (one value per sensor/device)
api/callAction?deviceID=%id%&name=setProperty&arg1=ui.%tskname%.value&arg2=Time:%20%systime%,%20Temp:%20%val1%
BMx280 (more value per sensor/device)
api/callAction?deviceID= %id%&name=setProperty&arg1=ui.%valname%.value&arg2=Time:%20%systime%,%20%valname%:%20%value%
No. You may be interested in this: https://forum.fibaro.com/topic/21685-fe ... setglobal/
This is not a perfect solution.
I am currently testing hassIO (hass.io). IM very impressed.
Unfortunately, automatic detection in hass by MQTT does not work for Easy ESP - it is reported to fix it (Easy Esp). They haven't been doing anything for this for a year and a half.
https://github.com/letscontrolit/ESPEasy/issues/977
I'm thinking about moving to ESPHome.
Users browsing this forum: Bing [Bot] and 104 guests
