SendToHTTP problem with URL lenght?
jopare
#1 Post by jopare » 19 Feb 2019, 21:30
Hi, currently I'm struggling with SendToHTTP with a longer URL. In general my config works when i use for example the following rule:
on System#Boot do
gpio,2,0
on Push#state do
if [Push#state]=1
SendToHTTP 192.168.0.50,8085,/room?cmd=set%20VC20_Steckdose_03%20on
gpio,2,0
No trouble with that, the above URL works from any Browser and also from this rule. When i try the same rule with the following URL, it doesn't work:
192.168.0.16,80,/control/trigger_event? ... rom_piface
But, this URL works also from any Browser. One, maybe interessting thing is, that the URL is trunkated in the log. The last 7 characters are missing.
I've also modified the required IPaddress, port, userid and password in the Generic HTTP device configuration. Any help will be appreciated, thanks in advance.
Re: SendToHTTP problem with URL lenght?
#2 Post by grovkillen » 19 Feb 2019, 21:44
Yes you're probably hitting the max length for a rule/command line.
Possible to shorten the URL?
jopare
#3 Post by jopare » 19 Feb 2019, 21:55
Unfortunately I can't shorten the URL. What's the max. length? I've read about a limitation problem in former releases but as far as i understood this was eliminated.
Thanks so far.
#4 Post by TD-er » 20 Feb 2019, 00:58
It may very well be the limit for these is 80 bytes.
The parameter (separated by a ',') has a length of 100 bytes in your example and I guess the limit for those is 80.
That still doesn't explain why you're missing 7 bytes.
The entire line is 128 bytes
SendToHTTP 192.168.0.16,80,/control/trigger_event?event_name=OnButPressed_roomsystem.0&event_source=alsapi.keyboard.from_piface
And that one may be limited to 120 bytes, which makes loosing 7 bytes a lot more likely.
Thing is we have had a lot of strange crashes, which appeared to be stack overflows while parsing the rules.
So it has been 240 bytes a while ago, but that's been lowered to keep the stack from overflowing.
A lot of this parsing has been looked into already to lower memory usage, but I guess if there's still some limit like this one, it hasn't been altered yet.
#5 Post by grovkillen » 20 Feb 2019, 05:46
jopare wrote: 19 Feb 2019, 21:55 Unfortunately I can't shorten the URL. What's the max. length? I've read about a limitation problem in former releases but as far as i understood this was eliminated.
Thanks so far.
SendToHTTP,192.168.0.16,80,/control/trigger_event?event_name=OnButPressed_roomsystem.0&event_source=alsapi.keyboard.from_piface
Just a thought, if you have any control over the receiving end you should get those event names shorten (bold in the text above).
jopare
#6 Post by jopare » 20 Feb 2019, 20:35
Thanks for your suggestions, I got it fixed with a very short Hostname instead of the IP-address.
#7 Post by grovkillen » 20 Feb 2019, 21:49
Good you got it fixed
Users browsing this forum: No registered users and 130 guests
