mega-20190305 4m reboot loop with new firmware and witty module
riker1
#1 Post by riker1 » 09 Mar 2019, 15:20
I experienced a boot loop
15:17:35.058 ->
INIT : Booting version: mega-20190305 (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
15:17:35.091 -> 55 : INIT : Warm boot #33 - Restart Reason: Exception
15:17:35.091 -> 58 : FS   : Mounting...
15:17:35.091 -> 63 : FS   : Mount successful, used 75802 bytes of 113201
15:17:35.423 -> 413 : CRC  : program checksum       ...OK
15:17:35.456 -> 424 : CRC  : SecuritySettings CRC   ...OK
15:17:35.456 -> 426 : CRC  : binary has changed since last save of Settings
15:17:35.456 -> 446 : INIT : Free RAM:27456
15:17:35.456 -> 447 : INIT : I2C
15:17:35.456 -> 448 : INIT : SPI not enabled
15:17:35.490 -> 461 : INFO : Plugins: 46 [Normal] (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
15:17:35.490 -> 464 : WIFI : No valid wifi settings
15:17:35.490 -> 466 : WIFI : Could not conn
15:17:35.490 -> Exception (29):
15:17:35.490 -> epc1=0x4000e1c3 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000018 depc=0x00000000
15:17:35.490 ->
15:17:35.490 -> ctx: cont
15:17:35.490 -> sp: 3ffffbd0 end: 3fffffd0 offset: 01a0
15:17:35.523 ->
15:17:35.523 -> >>>stack>>>
15:17:35.523 -> 3ffffd70:  0104a8c0 00000010 00000001 40275fd0
15:17:35.523 -> 3ffffd80:  0104a8c0 00ffffff 0104a8c0 4026cfa0
15:17:35.523 -> 3ffffd90:  00ffffff 0104a8c0 3ffffdc0 0000000e
15:17:35.523 -> 3ffffda0:  0104a8c0 00000001 00000010 00000002
15:17:35.523 -> 3ffffdb0:  0104a8c0 00ffffff 3fff36a8 0000000a
15:17:35.523 -> 3ffffdc0:  00000000 40106e74 04dd43e8 401004e8
15:17:35.523 -> 3ffffdd0:  40283596 3fff3d4c 402badf0 40106e74
15:17:35.556 -> 3ffffde0:  4029112d 00000017 60000200 40291152
15:17:35.556 -> 3ffffdf0:  04dd43e8 4027e7f3 3fff3d4c 3fff66dc
15:17:35.556 -> 3ffffe00:  4028385e 3fff3d4c 3fff66dc 00000000
15:17:35.556 -> 3ffffe10:  0000000a 3ffef9f0 3ffef96c 3ffefbdc
15:17:35.556 -> 3ffffe20:  00000000 402917eb 3ffef96c 3fff66dc
15:17:35.590 -> 3ffffe30:  00000018 3fff1fb1 00000002 3fff1fb1
15:17:35.590 -> 3ffffe40:  402bae38 00000064 3ffffe78 4027eeed
15:17:35.590 -> 3ffffe50:  3ffef96c 3fff66dc 3fff1fb1 3ffe84e4
15:17:35.590 -> 3ffffe60:  00000064 4027eed4 3fff66dc 3fff1fb1
15:17:35.623 -> 3ffffe70:  15a620a2 00008ec9 00000000 00000000
15:17:35.623 -> 3ffffe80:  00000000 00000000 00000000 00000000
15:17:35.623 -> 3ffffe90:  00000000 00000000 00000000 00000000
15:17:35.623 -> 3ffffea0:  00000000 00000000 00000000 4028028f
15:17:35.623 -> 3ffffeb0:  3fff66dc 00000002 00000002 402802dc
15:17:35.656 -> 3ffffec0:  00000000 3ffef9f0 3fff0818 00000000
15:17:35.656 -> 3ffffed0:  40296489 00000002 00000002 00000002
15:17:35.656 -> 3ffffee0:  402965ef 00000002 00000002 402965a3
15:17:35.656 -> 3ffffef0:  00000000 00000000 00000000 3fff623c
15:17:35.656 -> 3fffff00:  402966c6 00000002 00000002 00000000
15:17:35.689 -> 3fffff10:  4020903e 00000000 00000000 00000000
15:17:35.689 -> 3fffff20:  402b041d 00000001 3ffe8700 3fff3048
15:17:35.689 -> 3fffff30:  3fff1fb1 3fff0e7e 00000002 40234d15
15:17:35.689 -> 3fffff40:  00000000 fffffffe 00000001 4024bdb7
15:17:35.689 -> 3fffff50:  402b03bf 00000000 3fff1c5c 402161a4
15:17:35.722 -> 3fffff60:  3fff1fb1 3ffe8700 3fff22c0 4024c042
15:17:35.722 -> 3fffff70:  3fff1fb1 3ffe8700 3fff22c0 40253f00
15:17:35.722 -> 3fffff80:  00000000 00000000 00000000 4026a90c
15:17:35.722 -> 3fffff90:  3fff49d4 0000007f 00000064 feefeffe
15:17:35.722 -> 3fffffa0:  feefeffe feefeffe feefeffe 3fff3108
15:17:35.756 -> 3fffffb0:  3fffdad0 00000000 3fff3102 402689e0
15:17:35.756 -> 3fffffc0:  feefeffe feefeffe 3ffe88c8 40100721
15:17:35.756 -> <<<stack<<<
15:17:35.756 ->
15:17:35.756 -> last failed alloc call: 40106E74(81609704)
15:17:35.789 ->
15:17:35.789 ->  ets Jan  8 2013,rst cause:2, boot mode:(3,6)
15:17:35.789 ->
15:17:35.789 -> load 0x4010f000, len 1384, room 16
15:17:35.789 -> tail 8
15:17:35.789 -> chksum 0x2d
15:17:35.789 -> csum 0x2d
15:17:35.789 -> vbb28d4a3
any hints maybe?
T
Re: mega-20190305 4m reboot loop with new firmware and witty module
#2 Post by ThomasB » 09 Mar 2019, 21:57
Things to try:
(1) The crash occurs during WiFi init, so could be voltage sag problem. Try a different 5.0V power supply that has stable/clean power. Add caps on 5V rail too.
(2) Do a full flash memory reset. This will ensure a clean install. Hint, Load File: blank_4MB.bin
(3) Try an earlier release, such as mega-20190121.
riker1
#3 Post by riker1 » 10 Mar 2019, 08:24
Ok will try to reflash,
having the problem:
trying to connect
	espcomm_send_command: sending command header
	espcomm_send_command: sending command payload
	serialport_receive_C0: 46 instead of C0
trying to connect
trying to connect
while flashing.
how can I solve this, maybe a special pulldown etc?
Thanks T
riker1
#4 Post by riker1 » 10 Mar 2019, 08:25
did try different power supplies but did not solve it.
Users browsing this forum: No registered users and 121 guests
