I simply downloaded the archive and unpacked it. Then, I renamed the folder to RFLink since the Arduino IDE complains otherwise, specified the correct SKETCH_PATH and tried to compile.
update: It compiles, when I remove the Plugin_101.c in the Plugins folder.
Testbed for Plugin development
Re: Testbed for Plugin development
Strange.. but at least it works now
update: 1.6.9 does not care about what files are assigned to the project, it tries to compile all files in the directory tree.
As a result excluded files that should be skipped are still included.
Newer versions seem to have fixed that.. but at the same time have "fixes" that affect the timing.
So it is a hard requirement to use IDE 1.6.9 for compiling the ancient source publicly available? Since it affects timing?
Any plans to make some of the R46 core source available now the release is out? Like a new .zip file for us who's still interested in adding support for misc devices?
///Redferne
Any version from 1.0.5 to 1.6.9 seems to work fine.
Unknown for now..
