Lightwaverf mood switch
Hi!
Is this device fully working?
Domoticz recognizes the large 0/1 buttons but does not respond to any on the lower 4 small buttons...
Any ideas?
Any ideas?
Re: Lightwaverf mood switch
I think support for nearly every button type is implemented.
On/Off/Dimming is all there.
The mood buttons are translated to a "mood=xx" command which is not supported by Domoticz at the moment.
Mainly because I have no idea what the correct use would be.
So lets start by defining what action you expect from Domoticz side when you press these 4 small buttons?
Do you want ON/OFF functions, dimming, something else?
Hi!
Thanks for the quick reply
I think for me it would be best as if they just were sent as individual on switches.
That way they could be used for any purpose - linking to scenes, groups or individual devices as per whatever the user needs
Ok, please check what command is displayed when RFlink receives the small buttons..
I'll upload the log tonight when home from workStuntteam wrote:Ok, please check what command is displayed when RFlink receives the small buttons..
Hi!
Thanks for adding support for this (I'm sure i uploaded my log?!)..
Do I need to add support in Domoticz (my controller of choice ) ?
Cheers!
Cheers!
No idea.. I have not seen any attachments. still waiting for a log
You can also mail the log directly to frankzirrone@gmail.com
20;2B;Lightwave;ID=f2f790;SWITCH=af;CMD=ALLOFF;
2020;2D;Lightwave;ID=f2f790;SWITCH=af;CMD=MOOD=03;
20;2E;Lightwave;ID=f2f790;SWITCH=af;CMD=MOOD=02;
20;30;Lightwave;ID=f2f790;SWITCH=af;CMD=MOOD=01;
Hi!
So RFlink does detect this but Domoticz still doesn't recognise all the buttons even in teh latest betas...
Any ideas how to get this working in domoticz?
Cheers!
Cheers!
Well, RFLink has no issues recognizing this.
The main problem is that Domoticz has no use for the additional commands.
We also have no idea what the expected behaviour would be.
"Mood" scenarios can be done with scripts within Domoticz anyway. So perhaps these mood buttons should just be regular buttons so that users can assign actions to them..?
Yes please!
I'd really like domoticz just to treat the mood buttons as just switches so i can do what i want with them
It means that I can stick it on a wall and control several things in a room individually (WAF lol!)
Hello again!
Just checking is it you guys @ stunteam or the guys @ domoticz needed to get this done?
Should I contact someone over there?
Cheers!
Cheers!
