Trouble with RFLink on SYNOLOGY
EDreamZ
#1 Post by EDreamZ » 16 Nov 2016, 18:13
i've just installed RFLink on Arduino MEGA with USB cable, updated succesfully to the R44, connected to my Synology DS214Play with a Capacitor of 10 microFarad between RESET and Ground and finally correctly configured on my Domoticz APP.
i can read 2 Device, 1 Temp Sensor and an OWL CM180
the only strange thing is that RFLink stop to recive data after 5/7 minutes from start and the only thing i can do is to disconnect e reconnect it from the USB, but each time after 5/7 minutes it hangs.
what's wrong ?
Thanks in advance
Giuseppe
Stuntteam
Site Beheer
Re: Trouble with RFLink on SYNOLOGY
#2 Post by Stuntteam » 16 Nov 2016, 19:32
Connect RFlink to a PC and run RFlink loader to see if it also stops aftre 7 minutes or not..
Here you can see how to do that:
http://www.nemcon.nl/blog2/development
EDreamZ
#3 Post by EDreamZ » 18 Nov 2016, 17:29
Good Evening,
Ok...RFLink works good when connectd to the PC.
What's wrong with synology ? Could you please sudgest how to trouble shoot this ?
Thanks in advance...
Giuseppe
Stuntteam
Site Beheer
#4 Post by Stuntteam » 18 Nov 2016, 17:39
Check the USB chip on your Arduino.. is it an Atmega chip or a CH340 chip..?
EDreamZ
#5 Post by EDreamZ » 18 Nov 2016, 19:03
I bought it from you...it's an original ATMEGA2560.
Stuntteam
Site Beheer
#6 Post by Stuntteam » 18 Nov 2016, 19:20
Thats impossible because I do not sell anything.
You might have bought it from the Nodo shop, they have a CH340 and a non CH340 version.
The CH340 version works directly on the Synology and no capacitor is needed.
EDreamZ
#7 Post by EDreamZ » 18 Nov 2016, 21:17
:D :D :D sorry...
i know the story of the capacitor...and i put one capacitor of 10 microFarad between reset and GND when the RFLINK is connected to SYNOLOGY...
Stuntteam
Site Beheer
#8 Post by Stuntteam » 19 Nov 2016, 00:53
Well.. if you have an Arduino with CH340 you should not use the capacitor
EDreamZ
#9 Post by EDreamZ » 23 Nov 2016, 09:32
Again...my RFLINK is equipped with ATMEL serial port...works like a charme connected to a PC without the capacitor...works only for 5/7 minutes connected to a SYNOLOGY DS214Play with the capacitor...
anyone can help ? somebody has experienced my same trouble ?
Thanks in Advance
Giuseppe
Stuntteam
Site Beheer
#10 Post by Stuntteam » 23 Nov 2016, 10:48
Maybe get an Arduino Mega witha CH340 serial controller.. costs around 5 euros..
EDreamZ
#11 Post by EDreamZ » 23 Nov 2016, 11:26
Increasing or decreasing capacity could change something ?
Stuntteam
Site Beheer
#12 Post by Stuntteam » 23 Nov 2016, 14:15
Redferne
#13 Post by Redferne » 08 Dec 2016, 20:37
Stuntteam wrote:Maybe get an Arduino Mega witha CH340 serial controller.. costs around 5 euros..
Since I'm having a similar problem are you saying the Megas without CH340 are "bad"? Also bought a complete kit from Nodo Webshop.
///Redferne
Stuntteam
Site Beheer
#14 Post by Stuntteam » 08 Dec 2016, 22:50
The version with Ch340 works a bit smoother on a Synology than the version with atmega usb chip.
Alternative option is to get a FTDI usb to serial converter and hook the arduino with that to the Synology USB port (thus not using the USB on board of the Arduino)
Redferne
#15 Post by Redferne » 09 Dec 2016, 13:31
I'm running on a Raspberry PI 3. Would it make any difference? Please define "smoother", we are talking about a 57600 baud serial interface, not 4000000.
///Redferne
Stuntteam
Site Beheer
#16 Post by Stuntteam » 09 Dec 2016, 15:53
This thread is about known issues with Synology and Arduino devices..
Arduino's with an Atmega serial IO chip have this ussue while Arduino's with a CH340 serial IO chip do not.
