I am using the FastLed library and have build in diverse color animations such fire & color waves
These devices are controlled with node-red and domoticz (domoticz via node-red)
For example I use the node-red dashboard color picker to set the color and/or brightness.
Now I want to use the Mi-Light remote to do the same, just using the remote without the bulbs or zone-controls.
These remotes have a nice build, use touch-control and are cheap.
The problem is that the codes which I get from RFLink are of course Mi-Light specific.
20;29;MiLightv1;ID=DB48;SWITCH=04;RGBW=5390;CMD=COLOR;
20;2A;MiLightv1;ID=DB48;SWITCH=04;RGBW=4f90;CMD=COLOR;
20;2B;MiLightv1;ID=DB48;SWITCH=04;RGBW=8490;CMD=COLOR;
20;2C;MiLightv1;ID=DB48;SWITCH=04;RGBW=8b90;CMD=COLOR;
20;2D;MiLightv1;ID=DB48;SWITCH=04;RGBW=8c90;CMD=COLOR;
for example #3289c7 or for brightnes value 0 ....255
Or an indication how to proceed for a solution
