RFLink to send comand to smartwares device
dugolf
#1 Post by dugolf » 20 Dec 2016, 22:24
I use a Rflink with V1.1 R45
I try to send command to Smartwares radiator valve SH5-RDV-A
With the command
- 10;NewKaku;02a48800;2;ON
the valve does not receive it (i select rFS on the smartwares valve menu => it count down from 30 to 0)
A remote control smartwares SH5-TDR-A can be paire with the valve
When i connect the rflink to my windows computer, with the arduino SDK serial monitor i receive:
20;04;NewKaku;ID=02a48800;SWITCH=2;CMD=ON; when i press the up arrow
20;05;NewKaku;ID=02a48800;SWITCH=2;CMD=OFF; when i press the down arrow
In debug mode (20;03;DEBUG;Pulses=120;):
When i press the up arrow:
20;03;DEBUG;Pulses=120;Pulses(uSec)=390,30,270,60,270,1050,270,1050,270,90,240,120,240,1080,240,120,240,1080,240,1080,240,120,210,120,210,1110,210,120,210,1110,210,1110,210,150,210,150,210,1140,180,150,210,1140,180,150,210,1140,180,1140,210,150,180,150,180,1140,180,150,180,1140,180,150,180,1140,180,150,180,1140,180,180,180,1140,180,180,180,1140,180,180,180,1170,150,180,180,1170,180,180,180,1170,150,180,180,1170,150,180,180,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,6990;
20;04;DEBUG;Pulses=130;Pulses(uSec)=210,1110,150,180,150,180,150,1110,150,1110,150,180,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,210,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,6990;
20;05;NewKaku;ID=02a48800;SWITCH=2;CMD=ON;
20;06;DEBUG;Pulses=132;Pulses(uSec)=240,2430,150,1170,150,180,150,180,150,1170,150,1170,150,180,150,210,150,1170,150,1170,150,210,150,210,150,1200,150,210,150,1200,150,1170,150,210,150,210,150,1170,150,210,150,1170,150,1170,150,210,150,210,150,1170,150,210,150,1170,150,210,150,1200,150,1200,150,210,150,210,150,1200,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1200,150,210,150,1170,150,210,150,1170,150,210,150,1200,150,1170,150,210,150,210,150,1200,150,210,120,1200,150,210,150,1200,150,1170,150,210,150,6990;
20;07;DEBUG;Pulses=120;Pulses(uSec)=210,150,150,180,150,1110,150,1110,150,180,150,180,150,1110,150,180,120,1110,120,1110,150,210,150,210,150,1170,150,210,150,1200,150,1170,150,210,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,1170,150,210,150,210,150,1200,150,210,150,1200,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,180,150,1170,150,180,150,1200,150,180,150,1200,150,180,150,1200,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,180,150,1170,150,180,150,1170,150,180,150,1200,150,1170,150,210,150,6990;
When i press the down arrow:
20;02;DEBUG;Pulses=122;Pulses(uSec)=390,1020,300,60,270,60,240,1080,270,1080,240,90,240,90,240,1110,240,120,240,1110,240,1110,210,120,210,120,210,1110,210,120,210,1110,210,1110,210,150,210,150,210,1140,210,150,180,1140,210,150,210,1140,180,1140,180,150,180,150,180,1140,180,150,180,1140,180,150,180,1140,180,150,180,1140,180,180,180,1170,180,180,180,1170,180,180,180,1170,150,180,180,1170,150,180,180,1170,150,180,180,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,6990;
20;03;DEBUG;Pulses=128;Pulses(uSec)=240,180,150,180,150,1110,150,1110,150,180,150,180,150,1110,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,6990;
20;04;DEBUG;Pulses=118;Pulses(uSec)=210,180,120,1140,120,1140,120,210,120,210,120,1140,120,210,120,1200,120,1200,120,240,120,240,120,1200,120,210,120,1200,120,1200,120,210,120,210,120,1200,120,210,120,1200,120,210,120,1200,120,1200,120,210,120,210,120,1200,120,210,120,1200,150,210,120,1200,120,210,120,1200,150,210,120,1200,150,210,120,1200,150,210,120,1200,150,210,120,1200,150,210,150,1200,150,210,120,1200,150,210,120,1200,120,210,150,1200,150,210,120,1200,120,210,150,1200,120,210,150,1200,120,210,150,1200,120,1200,150,210,120,6990;
20;05;DEBUG;Pulses=130;Pulses(uSec)=240,1110,150,180,150,180,150,1110,150,1110,150,180,150,180,150,1170,150,1170,150,210,150,210,150,1170,150,210,150,1170,150,1170,150,210,150,210,150,1200,150,210,150,1200,150,1200,150,210,150,210,150,1170,150,210,150,1200,150,210,150,1170,150,1200,150,180,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1200,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1200,150,210,150,1170,150,210,150,1170,150,210,150,1200,150,1170,150,210,150,6990;
20;06;NewKaku;ID=02a48800;SWITCH=2;CMD=OFF;
The Rflink can decode the signal of the remote control but it seems to send it not correctly.
Is it possible that the rflink does not send the same pulses as the remote control does ?
wslotboom
Re: RFLink to send comand to smartwares device
#2 Post by wslotboom » 25 Jan 2017, 14:22
I am having the same problem. The radiator knobs can also be paired with standard KAKU remotes. So I tried to use two different remotes to test and got the ID's through RFlinkloader.
After getting the id's from the normal remote and from one of my generic KAKU remotes to Domoticz, I added them with the create RFLINK devices button and adding 20;4B to the ID. None of my radiator knobs was responding when the button in domoticz was pressed. They are however responding to both remotes if I press them.
To check if I did something wrong, I tried the same with with a KAKU socket switch. After adding the device with add RFLINK devices, I could turn the switch on and off.
Is there really nothing else we could do to make this work? It really looks like the Rflink is unable to send the right message to the devices and I would really like this to work.
Muth
#3 Post by Muth » 26 Jan 2017, 11:55
dugolf wrote:Hi,
With the command
I have exactly the same issue, when trying to pair with "Create RFLink Devices" button in hardware tab
20;0B;NewKaku;ID=000005;SWITCH=2;CMD=ON;
I have try with KAKU command and "Create RFLink Devices" button, but i can"t pair with my radiator valve.
20;0D;Kaku;ID=41;SWITCH=2;CMD=ON;
I'm in the last version RFLink_v1.1_r45
wich version are you wslotboom? Can you detail how you get it work ?
wslotboom
#4 Post by wslotboom » 28 Jan 2017, 10:23
I couldn' t get it to work with the RFLink only the physical remotes were working. When I tried to send te same code with the RFLink, like you did, I got no response. Hope they can fix this!
Stuntteam
Site Beheer
#5 Post by Stuntteam » 28 Jan 2017, 10:27
Picked up another set to test.. we are looking into it
wslotboom
#6 Post by wslotboom » 29 Jan 2017, 12:10
Thx stuntteam! If I can do something to help, please let me know.
Muth
#7 Post by Muth » 29 Jan 2017, 18:05
wslotboom wrote:I couldn' t get it to work with the RFLink only the physical remotes were working. When I tried to send te same code with the RFLink, like you did, I got no response. Hope they can fix this!
Sorry i make some english mistake.
wslotboom wrote:Thx stuntteam! If I can do something to help, please let me know.
Same here!
dugolf
#8 Post by dugolf » 31 Jan 2017, 21:17
New test:
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
=> 10;RFDEBUG=ON;
<= 20;01;RFDEBUG=ON;
SH5-TDR-A
Button UP:
20;08;DEBUG;Pulses=122;Pulses(uSec)=420,990,270,60,270,90,240,1080,270,1050,240,90,240,120,210,1110,240,120,210,1110,240,1110,210,150,210,150,210,1110,210,150,210,1140,210,1110,210,150,210,150,210,1140,210,150,180,1140,210,150,180,1140,210,1140,180,150,180,150,180,1140,180,150,180,1140,180,180,180,1140,180,180,180,1140,180,180,180,1170,180,180,180,1170,180,180,150,1170,180,180,150,1170,180,180,150,1170,180,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,6990;
20;09;DEBUG;Pulses=128;Pulses(uSec)=240,180,150,180,150,1110,150,1110,150,180,150,180,150,1110,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,6990;
20;0A;DEBUG;Pulses=118;Pulses(uSec)=210,180,120,1140,120,1110,120,180,120,180,120,1140,120,180,120,1200,120,1200,120,210,150,210,150,1200,120,210,120,1200,120,1200,150,210,120,210,120,1200,120,210,150,1200,120,210,120,1200,120,1200,150,210,120,210,150,1200,120,210,150,1200,120,210,120,1200,120,210,120,1200,120,210,150,1200,120,210,150,1200,120,210,150,1200,120,210,150,1200,120,210,150,1200,120,210,150,1200,120,210,150,1200,120,210,150,1200,150,1200,150,210,150,210,150,1200,150,210,150,1200,150,210,150,1170,150,1200,150,210,150,6990;
20;0B;DEBUG;Pulses=130;Pulses(uSec)=240,1110,150,180,150,180,150,1110,150,1110,150,180,150,180,150,1170,150,1170,150,180,150,210,150,1170,150,210,150,1170,150,1170,150,180,150,210,150,1170,150,210,150,1170,150,1170,150,180,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,1170,150,180,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1200,150,1170,150,180,150,210,150,1170,150,210,150,1200,150,210,150,1170,150,1170,150,210,150,6990;
20;0C;NewKaku;ID=02a48800;SWITCH=2;CMD=ON;
Button DOWN:
20;14;DEBUG;Pulses=122;Pulses(uSec)=390,990,270,90,240,90,240,1110,240,1110,240,120,210,120,210,1110,210,120,210,1110,210,1110,210,150,180,150,210,1140,180,150,180,1140,180,1140,210,150,180,150,180,1140,180,150,180,1140,180,180,180,1140,180,1140,180,180,180,180,180,1170,180,180,180,1140,180,180,180,1170,150,180,180,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,1200,150,210,150,6990;
20;15;DEBUG;Pulses=128;Pulses(uSec)=210,180,150,180,150,1110,150,1110,150,180,150,180,150,1110,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1200,150,210,150,1200,150,210,150,1170,150,180,150,1200,150,180,150,1200,150,210,150,1200,150,210,150,1200,150,180,150,1200,150,210,150,1200,150,180,150,1170,150,210,150,1200,150,1170,150,210,150,6990;
20;16;DEBUG;Pulses=118;Pulses(uSec)=210,180,120,1140,120,1110,120,210,120,210,120,1140,120,180,150,1200,150,1200,150,210,150,210,150,1200,120,210,150,1200,150,1200,150,210,120,210,150,1200,120,210,150,1200,120,210,120,1200,120,1200,120,210,120,210,120,1200,120,210,150,1200,120,210,120,1200,120,210,150,1200,120,210,120,1200,120,210,150,1200,120,210,150,1200,120,210,120,1200,120,210,150,1200,120,210,150,1200,120,210,150,1200,120,210,150,1200,120,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,1200,150,210,120,6990;
20;17;DEBUG;Pulses=130;Pulses(uSec)=210,1110,150,180,150,180,150,1110,150,1110,150,180,150,210,150,1170,150,1170,150,180,150,210,150,1200,150,210,150,1170,150,1200,150,210,150,210,150,1200,150,210,150,1170,150,1200,150,210,150,210,150,1200,150,210,150,1200,150,210,150,1170,150,1200,150,210,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,120,1200,150,1200,150,210,150,6990;
20;18;NewKaku;ID=02a48800;SWITCH=2;CMD=OFF;
Button UP again:
20;1F;DEBUG;Pulses=122;Pulses(uSec)=330,1020,330,30,240,90,270,1080,240,1080,240,120,210,120,240,1110,210,120,210,1110,210,1110,210,150,210,150,210,1140,210,150,180,1140,180,1140,210,150,180,150,180,1140,180,150,180,1140,180,150,180,1140,180,1140,180,180,180,180,180,1170,180,180,180,1170,180,180,180,1170,180,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,1170,150,180,150,210,150,1170,150,210,150,1200,150,210,150,1170,150,1170,150,210,150,6990;
20;20;DEBUG;Pulses=128;Pulses(uSec)=210,150,150,180,150,1110,150,1110,150,180,150,180,150,1110,150,1170,150,210,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,180,150,1200,150,180,150,1200,150,180,150,1170,150,180,150,1200,150,180,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,1170,150,210,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,1200,150,210,150,6990;
20;21;DEBUG;Pulses=118;Pulses(uSec)=210,180,120,1140,120,1110,120,210,120,180,120,1140,120,180,150,1200,150,1200,150,210,120,210,150,1200,120,210,150,1200,120,1200,150,210,120,210,150,1200,120,210,150,1200,120,210,150,1200,150,1200,150,210,150,210,150,1200,120,210,150,1200,120,210,150,1200,120,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,1200,150,210,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,1200,150,210,150,6990;
20;22;DEBUG;Pulses=130;Pulses(uSec)=240,1110,150,150,150,180,150,1110,150,1110,150,180,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,210,150,1170,150,210,150,1170,150,1170,150,210,150,210,150,1170,150,210,150,1170,150,210,150,1170,150,1170,150,210,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1170,150,210,150,1200,150,180,150,1200,150,180,150,1200,150,210,150,1200,150,210,150,1200,150,1170,150,210,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,1170,150,210,150,6990;
20;23;NewKaku;ID=02a48800;SWITCH=2;CMD=ON;
Button DOWN again:
20;26;DEBUG;Pulses=122;Pulses(uSec)=450,930,300,60,270,90,240,1080,240,1080,240,120,210,120,240,1110,210,120,210,1110,210,1110,210,150,210,150,210,1140,180,150,210,1140,210,1140,210,150,180,180,180,1140,180,180,180,1140,180,180,180,1140,180,1140,180,180,180,180,180,1170,180,180,180,1170,180,180,180,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,1170,150,210,150,6990;
20;27;DEBUG;Pulses=128;Pulses(uSec)=210,180,150,180,150,1110,150,1110,150,180,150,180,150,1110,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,180,150,1200,150,180,150,1200,150,180,150,1200,150,180,150,1200,150,180,150,1200,150,180,150,1200,150,180,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,1200,150,210,150,6990;
20;28;DEBUG;Pulses=118;Pulses(uSec)=210,180,120,1140,120,1110,120,210,120,210,120,1140,120,180,150,1200,120,1200,150,210,120,210,150,1200,120,210,150,1200,120,1200,150,210,150,210,150,1200,120,210,150,1200,120,210,150,1200,120,1200,120,210,120,210,150,1200,150,210,150,1200,120,210,150,1200,120,210,150,1200,150,210,150,1200,120,210,150,1200,150,210,150,1200,150,210,120,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1170,150,1200,150,210,150,6990;
20;29;DEBUG;Pulses=130;Pulses(uSec)=210,1110,150,150,150,150,150,1080,150,1110,150,180,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,1170,150,180,150,180,150,1170,150,180,150,1170,150,180,150,1170,150,1170,150,210,150,180,150,1170,150,180,150,1170,150,210,150,1170,150,210,150,1170,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,180,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,1170,150,210,150,6990;
20;2A;NewKaku;ID=02a48800;SWITCH=2;CMD=OFF;
When i try to send with the RFLINK:
10;NewKaku;ID=02a48800;SWITCH=2;CMD=ON;
Response is:
20;01;OK;
But the swartwares radiator valve does not accept it:
The valve count down from 30 to 0 ....
The RFLINK seems to send something because the let on the tramsmitter command blink ...
dugolf
#9 Post by dugolf » 31 Jan 2017, 21:30
It's the same with the OFF command:
10;NewKaku;ID=02a48800;SWITCH=2;CMD=OFF;
Stuntteam
Site Beheer
#10 Post by Stuntteam » 11 Feb 2017, 00:34
The command is not correct.
This is the right format:
10;NewKaku;02a48800;02;ON;
Muth
#11 Post by Muth » 15 Mar 2017, 23:24
Stuntteam wrote: 11 Feb 2017, 00:34 The command is not correct.
When i press "Create RFlink Devices" with the command below, there is no device created in device tab...
Stuntteam
Site Beheer
#12 Post by Stuntteam » 16 Mar 2017, 00:23
The Create RFLink Device popup requires the command format as received from devices..
thus this format:
Muth
#13 Post by Muth » 19 Nov 2017, 19:03
I have one for about 1 year, and i never getting a successful peering, with many trying and different method.
I see lot of problem in many forum, did someone have getting success with peering it?
