Reading data from ThingSpeak
First of all, I want to say that is very nice forum but so sad that development of ESP Easy is finish. I hope that somebody will continue Martinus work.
Now, I start to play with ESP8266 (ESP-01). I measuring temperature and sent it to Thingspeak. https://thingspeak.com/channels/223650 . As I want to make weather station which will be located outdoor and send data to Thingspeak, indoor I'll make second device with display with measuring data.
How I connect this second device to ThingSpeak and read temperature, humidity...? I read some topics on forum about MQTT import but I can't understand whole procedure of making firmware since I'm not Arduino user.
Thanks,
Sory about my english
Velja
Thanks,
Velja
Re: Reading data from ThingSpeak
I have similar setup and I use Globalsync.
One esp with oled is displaying values from a second esp. I use Wemos d1 mini units.
Have a look at http://www.letscontrolit.com/wiki/index ... GlobalSync
This is the last solution. I like to have server that allow me and somebody else to view what's happen when I'm not at home.
Still possible. Using rules I also update thingspeak with data from both ESP.
https://thingspeak.com/channels/21739
Field 1,2 and 3 are one ESP with 3 pcs of ds18b20.
Field 4 is another esp with Oled and a SI7021sensor. I have the scrolling oled plugin. This ones sends data from both ESP to thingspeak by rules.
Both units also send data individually to my own domoticz server.
Exellent! Is possible to send me your rules to see how to do that?
Yes, I will do that in evening when home.
I made my best to explain below. Maybe confusing but let me know any questions. I'm sure there are more experience menbers that can help out to.
1: Enable Global sync on devices
2: Enable Rules
Test that Global sync is working. It is described in the wiki. If you allready set your ESP up you might have to change the device task number i.e Number 1 will also be number 1 on the other unit.
In rules in one of the ESP I have this code:
You have to replace XXXXXXXXXXXXXX with your key to thingspeak. Also change the part after each fieldx=to match your sensors. In My case I have 4 sensors reported to thingspeak. What happens is that when the Ute#Temperature is updated (It is set to 60 seconds) the SendToHTTP part is triggered and sends all data to thingspeak. You should have the sensor for triggering on same ESP as the rules. I guess this means that some senor data could be upto 1 minute old, however this doesnt matter for me just measuring outdoor and indoor temperatures.
2: Enable Rules
On Ute#Temperature do
SendToHTTP 184.106.153.149,80,/update.html?key=XXXXXXXXXXXXXX&field1=[Ute#Temperature]&field2=[t1#Temp]&field3=[t2#Temperature]&field4=[InneK#Temperatur]
Thank you! I wait some parts to come from China and when they come I 'll try.
Users browsing this forum: No registered users and 35 guests
