DHT22 Problem
DHT22 Problem
I use the R57 version. Also in the previous versions of the problem occurred.
On GPIO 14 I have a DHT 22 sensor is connected.
Unfortunately only 11,20 appear to temperature.
Hygro is 29.3%.
The values correspond to about half the correct values
Why is that? What could be the problem?
A 18B20 sensor working properly
Hygro is 29.3%.
Re: DHT22 Problem
low voltage could be an issue. do you have a pull-up resistor on the data pin?
Re: DHT22 Problem
The voltage is 3.5 volts
The resistance between VCC and the Data pin is 4.7K
Re: DHT22 Problem
I had a similar issue where it would read about half value every few minutes on R39 but updating to never version fixed it.
Other things to try would be a different pin on the ESP, reset command from the serial interface and flash the latest github revision again to do everything fresh.
Re: DHT22 Problem
another GPIO I have already tested without success
How does the reset command from the serial Interace?
Re: DHT22 Problem
in arduino software under tools menu open serial monitor and type reset and press enter, esp will reboot to factory default config.
Re: DHT22 Problem
I also get false readings from AM2302(similar to DHT22), 5k1 resistor to data pin, 3.7v power(single liion cell).
Using this in deep sleep mode, i think the priblem is in a sensor work after *awake* from sleep. temperature readings are 4 degrees error - humidity 50% error. Many people on the web report problems with am2302/dht22.
Solution - i ordered SI7021 and BME280 for my deepsleep mode sensors.
Re: DHT22 Problem
VasilijHCN wrote:I also get false readings from AM2302(similar to DHT22), 5k1 resistor to data pin, 3.7v power(single liion cell).
Using this in deep sleep mode, i think the priblem is in a sensor work after *awake* from sleep. temperature readings are 4 degrees error - humidity 50% error. Many people on the web report problems with am2302/dht22. .
I am experiencing the same - however my module isn't running with deepsleep. I have using AM2302/DHT22 on other ESP8266 modules, with the russian (wifi-iot.ru) software and it's been very reliable, as long as the power is 3.3V - if it drops just slightly below 3.3 it doesn't work and AM2321 or Si7021 is a better fit
- Jan
Jan Chrillesen, Denmark
Re: DHT22 Problem
Same here. I have an AM2320, which runs fine with an Arduino. No results with ESP8266 (nan),
Strange, a DHT11 is running fine with the ESP8266.
Re: DHT22 Problem
Same problem here with DHT22 sensors.
I tried two different sensors with multiple boards type ESP-01 and ESP-12. The vallues are allways 0.00.
When i try it with LUA-code its working.
Any suggestions? I would really like to continue with ESPEASY.
Re: DHT22 Problem
Fill in any IDX number not being zero ??
other people, same problem, maybe here?
http://www.esp8266.nu/forum/viewtopic.p ... =755#p3685
or
http://www.esp8266.nu/forum/viewtopic.php?f=5&t=798
or
Re: DHT22 Problem
Helm wrote:Same problem here with DHT22 sensors.
Did you select : DHT Type = "DHT22" in the task-setting of the device tab, and press 'Submit' ?
When you leave it default it will select DHT11 and this will not work.
Re: DHT22 Problem
Bingo, the missing IDX number was the problem.
That cost me some time, thank you tozett for the hint.
Re: DHT22 Problem
Are you shure that you have connected the right gpio? The pinnumber is not the same as the gpio number (on nodemcu v1 d7 pin is not gpio 7 but 13). I got the "nan" status because of this.orca30 wrote:Same here. I have an AM2320, which runs fine with an Arduino. No results with ESP8266 (nan),
Re: DHT22 Problem
Hi.
If your DHT11/22 reads most of the time 'nan', you have to change a value in the source code of _P005_DHT.ino, around line 98.
Change from "delayMicroseconds(40)" to "delayMicroseconds(20);" :
The value 40 has to be changed to 20, as 40 microseconds is the maximum, and 20 the minimum. Choosing to use the maximum value as not a good choice. I think it really should be changed in the Github trunk code...
pinMode(Plugin_005_DHT_Pin, OUTPUT);
// DHT start condition, pull-down i/o pin for 18ms
digitalWrite(Plugin_005_DHT_Pin, LOW); // Pull low
delay(18);
digitalWrite(Plugin_005_DHT_Pin, HIGH); // Pull high
delayMicroseconds(20); // was 40. With 40, sensor returns NaN most of the time...
pinMode(Plugin_005_DHT_Pin, INPUT); // change pin to input
delayMicroseconds(10);
Re: DHT22 Problem
Seems good in r90 ![Lach :)](./images/smilies/icon_e_smile.gif)
Edit: woops, is in fact r90...
Re: DHT22 Problem
Changed another timing setting in DHT plugin. I got a few incorrect values in the domoticz chart (half the actual value). Seems fixed now in R90.
Re: DHT22 Problem
So, I got the DHT22 and the DHT11 running with a home-brew ESP8266 + USB adapter for power supply. Now I have a NodeMCU board on which I connected the DHT 22 and DHT 11.
I am using pin D7 (GPIO13), I have set the index and the DHT type correctly. I have applied the patch below (set DelayMicroseconds to 20). However, I get NaN most of the time and (very) seldom strange values from the DHT11 (12 degrees instead of 22).
Is it a problem with the 3,3v supply of the NodeMCU board? Did anybody manage to get the DHTs to run with the NodeMCU?
regards,
orca30
regards,
orca30
Re: DHT22 Problem
I had same problem, you must fill in IDX number, after that works, but this should be fixed.
Re: DHT22 Problem
Please check the voltage going to the DHT-11, and check the data sheet for it as well. It requires a pullup resistor and recommends a capacitor.
I have a nodeMCU(v1) and DHT-22 with a 2A wallwart which puts out 5.5V and I have a big capacitor on the 3.3V rail. Works better, but I think the AMS1117 and diode cut it down too much for the DHT-11 if you do not have really good power. I don't have problems when I use better voltage regulators.
If you really want to stick with NodeMCU I would suggest a BME-280.
Re: DHT22 Problem
My DHT22 is running now a few hours, but the Humidity reading is too high:
![Beschaamd :oops:](./images/smilies/icon_redface.gif)
Re: DHT22 Problem
I usually have that problem with the DHT11, but no the DHT22... Could be a bad sensor. No idea if all the manufactures test them before they send them out.
Might be cheaper to use a more expensive and reliable sensor.
Re: DHT22 Problem
I am now trying to calibrate. 24hour with salt in a jar - it should be around 75%. Then I try to put in a jar filled with water - it should be around 100%.
SI7021 seem to be accurate out of the box.
BMP280 - is measuring +1C out of the box
BMP180 - temp OK, pressure little bit different than BMP280 (+-1hPa) who knows what is closer to reality.
Re: DHT22 Problem
Hi adrianmihalko,adrianmihalko wrote: ↑28 Sep 2016, 20:27 I am now trying to calibrate. 24hour with salt in a jar - it should be around 75%. Then I try to put in a jar filled with water - it should be around 100%.
I know it's an old post, but...
Did you managed to solve the AM2320 LOW humidity reading without calibration?
I bought 6pcs of it, 2pcs from one seller and 4pcs from another!
First I thought that the sensors are defective regarding the humidity measurement results.
All my sensors attached to one ESPEasy unit are measuring almost the same humidity level from 47% to 51% (HTU21D, SI7021, AM2301, DHT11, DHT22), but those AM2320 sensors always measuring to LOW humidity level from 31% to 33% again attached to the same device.
![Bedroeft :(](./images/smilies/icon_e_sad.gif)
The AM2320 temperature reading is fine, but the humidity reading are just terrible!
Maybe it's a library issue?
Also, I managed to develop a plugin for the AM2320 sensor on the I2C bus, but again, I got to LOW humidity readings.
Any thoughts?
Kind regards,
Viktor
