AM2320 on I2C bus
beic
AM2320 on I2C bus
#1 Post by beic » 21 Apr 2017, 14:56
Hi there,
Anyone has a AM2320 sensor setup on the I2C bus?
I tried with pullup resistors, but the ESPEasy doesn't report any new I2C address found.
Any help, please!
Kind regards,
Viktor
p.s. The sensor is working with one wire setup with DHT22 device selected.
beic
Re: AM2320 on I2C bus
#2 Post by beic » 23 Apr 2017, 18:28
Anyway, I wrote my own Plugin for it, regarding the I2C bus.
Also, the ESPEasy will not detect the sensor on the I2C bus by "I2C Scanner" for some reason, but the sensor is working on the 0x5C address.
papperone
#3 Post by papperone » 10 May 2017, 16:23
hi, will you mind to share the plugin?
beic
#4 Post by beic » 10 May 2017, 16:39
papperone wrote: 10 May 2017, 16:23 hi, will you mind to share the plugin?
Already included to the default build by krikk, anyway you can use it with the DHT22 lib too as a single-bus!
papperone
#5 Post by papperone » 10 May 2017, 16:46
beic wrote: 10 May 2017, 16:39
what about connection? I don't think DHT22 and AM2320 are pin compatible... do you have any info about it ?
#6 Post by Shardan » 10 May 2017, 18:31
papperone wrote: 10 May 2017, 16:46 what about connection? I don't think DHT22 and AM2320 are pin compatible... do you have any info about it ?
Have a look at the datasheet: https://akizukidenshi.com/download/ds/aosong/AM2320.pdf
On page 3 you'll find the pinout of the AM2320.
On page 21 is a schematic for using it as a one-wire device.
beic
#7 Post by beic » 10 May 2017, 19:54
Shardan wrote: 10 May 2017, 18:31
+1 Kudos for that! ;)
papperone
#8 Post by papperone » 12 May 2017, 07:54
thanks !!!!
