I have two somfy blinds that have worked perfectly with RFLink versions R42-R45.
After upgrading to R46, they stopped working.
I have tried to clean the RTS codes and pair the blinds again without success.
Does anyone else have the same problem?
RTS stopped working in R46
Re: RTS stopped working in R46
There were no changes, send a mail to frankzirrone@gmail.com for personal support..
Thanks, I'll do that.
A workaround is to revert back to R45.
I reverted back to R45 and I was able to pair the blinds and control them (up/down).
Then, upgraded to R46 again and the blinds stopped working.
I have also an issue usign R46. I'm able to pair 3 awnings each motor separated and the three at the same time (like the 5th position in the Telis 4 RTS remote) but after some days using them with Domoticz, it stops working.
RFlink still has the programing in the positions:
10;RTSSHOW;
RTS Record: 0 Address: C69141 RC: 048E
RTS Record: 1 Address: C59141 RC: 03B8
RTS Record: 2 Address: C49141 RC: 0490
RTS Record: 3 Address: 3A0F0F RC: 0413
RTS Record: 4 Address: C89141 RC: 148D
RTS Record: 5 Address: 000000 RC: FF56
RTS Record: 6 Address: 000000 RC: 0000
RTS Record: 7 Address: 000000 RC: 0000
RTS Record: 8 Address: 000000 RC: 0000
RTS Record: 9 Address: 000000 RC: 0000
RTS Record: 10 Address: 000000 RC: 0000
RTS Record: 11 Address: 000000 RC: 0000
RTS Record: 12 Address: 000000 RC: 0000
RTS Record: 13 Address: 000000 RC: 0000
RTS Record: 14 Address: 000000 RC: 0000
RTS Record: 15 Address: 000000 RC: 0000
and the command are accepted, but the response is too slow (I even got an OK a couple of seconds after writing the second comand) and the awnings do not move:
10;RTS;C89141;0;UP;
10;RTS;C69141;0;UP;
20;0E;OK;
10;RTS;C59141;0;UP;
20;0F;OK;
20;10;OK;
It happened the same thing the first time and I thought it was due to domoticz, so I resetted everything and reprogramed it, but after 3 days woring this second time, I keep having the same issue.
I'l install R45 and report if there is any difference.
10;RTSSHOW;
10;RTS;C89141;0;UP;
10;RTS;C69141;0;UP;
20;0E;OK;
10;RTS;C59141;0;UP;
20;0F;OK;
20;10;OK;
