Trying to use buzzer in espeasy[SOLVED]
I am using espeasy v2.0.0-dev11
when I use the pulse command http://192.168.1.99/control?cmd=Pulse,14,1,200 I am able to get a beep from the buzzer
but I can't seem to use the tone command
when I use the tone command http://192.168.1.99/control?cmd=tone,14,330,2000 I get this error message
Unknown or restricted command!
need help
thanks
Raj
need help
thanks
Raj
Re: Trying to use buzzer in espeasy
tried rtttl command but same error message
http://192.168.1.99/control?cmd=rtttl,1 ... =180,c,e,g
https://www.letscontrolit.com/wiki/inde ... zer_(RTTL)
This is at the moment only available in the "test" build, not in normal build.
Re: Trying to use buzzer in espeasy[SOLVED]
Thanks, it's fantastic !
I got my buzzer working, it plays pulse and melodies. But the after notes have been played the buzzer keeps beeping one continous note.
It only stops after I reset.
Any suggetions how to fix this?
Are you still on version dev 11?
Did you also test to send something like a buzzer off command? (not sure if it exists, just an idea)
I’m on the latest stable ‘test’ firmware. I dont think there is a stop command?
I dont think I have the above isue. My tune does not loop, it plays once and the a different note endless beeps.
But it's still not a stable code.
Hi, Newbie here, I have a strange issue, my active buzzer keeps a continuous beep and doesn't stop after the pulse, tone or RTTTL. What could be the issue?
