868Mhz receiver
868Mhz receiver
Could someone please point me to good source of 868MHz receivers working with RFLink? There are plenty of 433MHz modules on ebay but I've not found 868Mhz version.
Re: 868Mhz receiver
As mentioned in viewtopic.php?f=11&t=3308 the only 868 MHz supported module at the moment is the 868 MHz version of the Aurel transceiver, which is not available from ebay or the usual chinese shops. It's my understanding that there's work going on to support the CC1101, which is much cheaper. Since it's a SPI based module it's not a plug'n'play replacement for the Aurel. I recently found a 868 MHz receiver module from RelyRF called WR-RY-6R that looks very much like the 433 MHz modules supported by RFLink - but this is also not available on ebay/ali - however I contacted the manufactor and they were happy to sell me samples for $3.50 + shipping, so I ordered a few. When they arrive I'll test them. Eventually CC1101 will probably be supported and be a better solution
- Jan
Jan Chrillesen, Denmark
Re: 868Mhz receiver
OK, so I'm waiting for your impression WR-RY-6R.
Re: 868Mhz receiver
any news from cheap transceivers on 868 ? WR-RY-6R or CC1101 compatibility ?
thanks in advance
best regards
Arno
thanks in advance
best regards
Arno
