SelectRemote & RFLink, not transmitting correctly
yos2000
#1 Post by yos2000 » 12 Oct 2017, 12:48
Hi all,
Recently i bought an RFLink to control de SelectRemote powerswitches I have (from domoticz)
I'm running into the following issue:
When I press the remote control buttons is see this is the logging:
20;0C;PT2262;ID=43;SWITCH=0;CMD=OFF;
When I want to send that message like this: 10;PT2262;ID=43;SWITCH=0;CMD=OFF; nothing happened.
I wired up a rf433 sniffer and when I press the remote again the sniffer says something like this.
Decimal: 4128960 (24Bit) Binary: 001111110000000011000000 Tri-State: 011100001000 PulseLength: 224 microseconds Protocol: 1
Raw data: 6988,212,716,176,664,680,212,676,232,660,244,660,236,688,216,664,240,212,696,172,696,228,668,240,684,188,720,200,680,224,676,224,700,632,260,684,212,228,676,216,712,180,712,220,684,220,684,204,716,
When I send the command manually it returns different values:
Decimal: 5570561 (24Bit) Binary: 010101010000000000000001 Tri-State: FFFF0000000F PulseLength: 190 microseconds Protocol: 1
Raw data: 5924,188,584,588,168,220,564,604,180,208,588,584,164,224,556,596,184,208,592,192,572,224,540,224,564,220,552,216,588,184,580,200,24,20,132,32,152,24,72,76,24,68,212,24,76,292,2000,52,128,
How can I calculate the right values to send?? Apperently I am doing something wrong, or I just don't get it. (I am a beginner with RF signals)
Hope you guys can get me in the right direction!
EDIT: Is there a differnce between PT2262 and Tristate?
wim16
Re: SelectRemote & RFLink, not transmitting correctly
#2 Post by wim16 » 12 Oct 2017, 14:43
The command you send should be a little different:
10;PT2262;43;0;OFF
See the examples on http://www.rflink.nl/blog2/protref
yos2000
#3 Post by yos2000 » 12 Oct 2017, 15:34
Yeah, tried that too, but also with a incorrect result.
Domoticz regognizes the remote control. But when domoticz sends, it also sends differtent data than the remote control, so the reciever will never recieve a correct signal.
I don´t get that part....
Stuntteam
Site Beheer
#4 Post by Stuntteam » 12 Oct 2017, 16:17
make a debug log from the buttons on your remote as explained here:
http://www.rflink.nl/blog2/development
and mail that to frankzirrone@gmail.com
then I will take a look
yos2000
#5 Post by yos2000 » 12 Oct 2017, 17:06
Thanx, just did that!
yos2000
#6 Post by yos2000 » 15 Oct 2017, 14:44
Did you find time to look at it already?
yos2000
#7 Post by yos2000 » 01 Dec 2017, 13:41
Ok, so I mailed the logging 6 weeks ago.... never had any response.
i ssomething wrong?
Stuntteam
Site Beheer
#8 Post by Stuntteam » 01 Dec 2017, 14:52
just extremely busy..
Users browsing this forum: No registered users and 40 guests
