GAL WS-1501 incorrectly shows negative temperatures.
Igrek
#1 Post by Igrek » 22 Oct 2017, 10:45
Hello!
I have simple meteo GAL WS-1501.
RFLink defines how "InoValley_SM200". In the summer it works perfectly. At temperatures below zero, the temperature is incorrect. With the real -0.1, it shows -101.2 С :shock:
In logfile "RFLink: 20;8B;InoValley_SM200;ID=02b2;TEMP=83FE;"
As the temperature decreases, the values increase! At minus 1.2 degrees, the values in the RFLink protocol are "TEMP = 83F4;"
Where it can be repaired, in RFLink or in Domoticz?
padrino
Re: GAL WS-1501 incorrectly shows negative temperatures.
#2 Post by padrino » 17 Feb 2019, 15:07
even if this is a bit old, but as the problem still exits with rflink (I am using it with iobroker, though)...
You can calculate the correct value from the given.
Here it starts with 83FF for -0.1°C. Ignoring the "8" leaves 3ff hex, or 1023 dec.
RFlink decodes it to -102.3°C (= rflink_tmp).
So the correct temperatur to use is
rflink_tmp * (-1) - 102.4
I use this calculation for every rflink_tmp < -50. This should cover the range of possible temperatures here. ;)
CU,
padrino
