G’day,
Am a newbie, and yet to get past the init flash stage.
Ran the flash (with correct port, size 4096 and build 120) but unable to get a AP/ hotspot
The flash.cmd shows no errors and the WeMos D1 mini V2 Led blinks while flashe.cmd is executing.
After a reset I get the following o/p:
A line of junk characters
Init: Booting Build nr:120
Wifi: No SSID
Init: I2C
Init Boot OK
Init: Normal boot
A minute later get
WD: Uptime 0 ConnectionFailure 0 FreeMem 27016
What dumb thing am I doing wrong
Tks
Failed to get a AP/Hotspot
Re: Failed to get a AP/Hotspot
Not sure but you may program the unit to your WiFi by sending those commands over the serial communication.
G'day,
So what you are saying, is that I can type commands over the serial connection that is currently displaying:
WD : Uptime 59 ConnectionFaiures 0 FreeMem 26568
Have tried a few inputs on the serial but with no response.
What commands should I send?
Grant
Grant
Isn't this the same question like here?
viewtopic.php?f=4&t=3785&p=20905#p20905
Yes like DeNB3rt said in the other thread.
The complete list of commands is found here: https://www.letscontrolit.com/wiki/inde ... _Reference
Users browsing this forum: Ahrefs [Bot] and 21 guests
