Increase number of devices
I'm using ESPeasy v2.0.0-dev12. Firmware has limit to 12 devices.
Is possible to increase this limit?
I would like to connect 5 relays (Switch input) and 10 DS18B20 sensors on one gpio pin.
For each relay I need "virtual mqtt device" (Output - (Domoticz MQTT helper)).
I would like to add devices for system states: uptime, wifi signal and freemem - it is next 3 devices.
Is there any reason for only 12 devices?
Re: Increase number of devices
How are you going to connect the 5 relais?
Finding 5 free GPIO's is already hard and then you also need one for the 1-wire.
I'm using Wemos D1 mini https://wiki.wemos.cc/products:d1:d1_mini
I found on wiki Why only 12 tasks?.
But there is no info how to compile firmware with more devices support.
I found limits in file ESPEasy.ino:
What is the reason for comments with exclamation mark?
#define TASKS_MAX 12 // max 12!
#define CONTROLLER_MAX 3 // max 4!
#define NOTIFICATION_MAX 3 // max 4!
Look here
https://github.com/letscontrolit/ESPEasy/issues/590
Hexenmeister explains ....see:
This is possible (up to about 28 without enlargement of config.dat), but some addresses have to be recalculated ...
This recalculation is a clever way, that I didn't know a half year ago.
Without that recalculation I was able to run 24 tasks, but memory of the first controller position is overwritten,
so I used the second controller position.
#define DAT_OFFSET_TASKS 4096 // each task = 2k, (1024 basic + 1024 bytes custom), 12 max
#define DAT_OFFSET_CONTROLLER DAT_OFFSET_TASKS + (DAT_TASKS_SIZE * TASKS_MAX) // each controller = 1k, 4 max
#define DAT_OFFSET_CUSTOM_CONTROLLER DAT_OFFSET_CONTROLLER + (DAT_CUSTOM_CONTROLLER_SIZE * CONTROLLER_MAX) // each custom controller config = 1k, 4 max.
Thank you, it works!
Why someone will waste a Task/Device for a system variable, can't be changed remotely anyway and you can publish from rules.
In any case use a $1IO Expansion Board I2C or $1.4 IO Expansion Board I2C that will save you IO on the main board.
You can trigger multiple/different GPIO using a single mqtt import/rules and %eventvalue% variable.
Regards,
Regards,
Just as long as you use it as an output.
Use a 16port MCP21017 as an input and you will see...
Rgrds
Rgrds
I support this as I'm designing new PCBs MCP23017 based (same as the one I've already for 8 relays + 8 inputs) and one of them I thought to have it 16 inputs, stack-able to be able to connect up to 8 (as MCP23017 can be set up to 8 different addresses) and go up to 128 inputs which of course will make ESPEasy completely unusable and I'm really puzzled on how to overcome this limits (power-wise ESP8266 has the capability to handle that many logical inputs, simply not possible with current ESPEasy design)
I've a similiar circuit already running with PCF8574, stackable PCB......
That's why i suggested some changes on github already.
Don't leave adress inputs "floating".
The address inputs need Vcc or ground. I've a 10KOhm pull up resistor on all Ax-Inputs and jumpers to set them to ground as necessary.
I use the expander for both input and output and works as expected, the only limitation is that you have to waste a Task for each input.
Anyway I never use built in GPIO for direct input or output as per say, only via expander and/or optoisolator.
Regards,
You use a 23017 with 16 inputs on ESPEasy with 12 tasks?
As said i use a similiar solution with two PCF8574, one as input, one as output, that works flawlessly.
Anyways i need much more then 8 or 16 inputs so i've requested a solution on github already, just one task per
PCD8574 or MCP23017 just reading the byte (PCF8574) or word (MCP23017) and giving the binary value back to the home control.
As soon as i'm homecan you explain with a schematic?
As a note, you can use one device for both input and output(on different pins).
Great idea.
I know - it's a remote control that uses 8 buttons and 8 status LED's.
I was wondering if i should use a 23017 but the PCF8574 were in the shelf and PCB layout is easier for this configuration
Users browsing this forum: Bing [Bot], Google [Bot] and 0 guests
