Good morning everyone
Found this 433mhz remote that looks quite nice (always important for WAF around the house)
https://www.aliexpress.com/item/Anysane ... autifyAB=0
And I saw on rfblog that there is a way in rflink to learn codes
Before I jump in the (for now) unknown, would following be achievable ?
step 1: rflink to learn the fixed codes emitted by each button -> the remote has fixed codes which for me is fine, as don't want to clone any existing remote
step 2: have domoticz react on each button push
if above isn't possible.. would it be possible then with a kaku/trust set (typically one remote, many power plugs), toss aside the plugs and only use the remote ?
thanks
Achievable ? learning codes from a RF remote for domoticz piloting
Re: Achievable ? learning codes from a RF remote for domoticz piloting
I did not use the learning mode myself but for the kaku remote you don't need it. The remote codes are recognized directly.
Also, you can buy a kaku remote without power plugs, or you can assign a different code to the power plugs so you can trigger those through rflink only and use the remote to trigger other events.
indeed - i see this remote -not quite same price of course as from ali : around €13 locally while the ali one was at 6.15 -
but then I buy pretty much just around the corner and could apparently control more stuff
https://www.praxis.nl/gereedschap-insta ... 02/5205720
or is this remote "too advanced" with its 4x canals for RFLink ?
(EAN: 8713439700565)
No problem. The number of channels indicates how many kaku codes the remote can send but a keypress will always send just one of those.
