This means that the controller (Domoticz) has to know the range of PWM-levels and convert the dimmer level (0-100%) to PWM.
I'd rather have this conversion done in ESPEasy because the max PWM level is also depending on the type of PWM (native or PCA9685).
I tried to use the formula in the device setting but this seems to be ignored by the plugin. I also tried to do the math in rules (see below) but that does not seem to work either; the PWM level is set to the input level and ignores the formula.
on DimmerImport#Level do
PWM,14,[DimmerImport#Level]*1024/100,1250
