I am interested in an RFLink (https://www.nodo-shop.nl/en/rflink-gate ... cable.html). At home I have a Friedland / Honeywell alarm system.
It is this base station (https://www.amazon.de/Friedland-SA5F-Fu ... B000ONWARE) on 433Mhz basis and these door sensors (https://www.amazon.de/Friedland-SU4F-zw ... HQRE32Q7JN), also on 433Mhz basis.
It would be important to be able to read the door sensors with the RFLink.
So if a door is opened in Domoticz an alarm should be triggered.
My door sensors are already recognized with the Libary RC-Switch (https://github.com/sui77/rc-switch).
Is it possible with RFLink?
Thank you
Re: Friedland / Honeywell alarm system
Probably not helping you, but these sensors seem to be similar to the Elro HA-68S alarm set i have, on 868MHz: http://voordeelmuis.nl/cgi-bin/v.cgi?a=d&d=1004418. Maybe these come from the same producer.
On the amazon website it seems the friedland system is also available in 868MHz.
The Elro 868 sensors are unfortunately not yet recognized by the software.
Domoticz @ Raspberry Pi 3 - RFXcom @ 433MHz - RFLink @ 868MHZ - ESP8266
For 433mhz it should be fine..
Please check http://www.rflink.nl/blog2/development
