Sensirion SHT30 supported?
remmie75
#1 Post by remmie75 » 01 Dec 2016, 13:49
I have a wemos d1 mini pro flashed with esp easy 147 and a wemos shield with sht30. Is it supported by esp easy? Sht1x is supported but I don't know if sht30 is backwards compatible. Any plans to support if not supported?
dzikus
Re: Sensirion SHT30 supported?
#2 Post by dzikus » 16 Jan 2017, 12:08
coldman
#3 Post by coldman » 31 Jan 2017, 13:27
dzikus wrote:I just created working plugin https://github.com/dzikus/ESPEasyPlugin ... _SHT3X.ino .
I am newbie here, could you please explain how to upload your plugin to espeasy?
dzikus
#4 Post by dzikus » 11 Feb 2017, 11:07
1. You need ESPEasy source code for example:
git clone https://github.com/letscontrolit/ESPEasy
or download and decompress https://github.com/letscontrolit/ESPEas ... master.zip
2. Download my plugin https://github.com/dzikus/ESPEasyPlugin ... _SHT3X.ino into ESPEasy directory.
3. Open ESPEasy.ino in Arduino compile and upload :).
dzikus
#5 Post by dzikus » 11 Feb 2017, 11:26
coldman wrote: I am newbie here, could you please explain how to upload your plugin to espeasy?
I made the release of R148 with my plugin for SHT30 https://github.com/dzikus/ESPEasy/relea ... 48%2BSHT30
coldman
#6 Post by coldman » 26 Feb 2017, 12:00
Thanks for your job, everything is fine, sensor is working.
EmKa
#7 Post by EmKa » 20 Mar 2017, 03:54
any news on this for the official release?
krikk
#8 Post by krikk » 21 Mar 2017, 21:59
budda85
#9 Post by budda85 » 29 Mar 2017, 20:27
I've downloaded and flash the Version 2.0.0-dev7, but I can't find the SHT30 in the Dropdown menu.
#10 Post by Shardan » 29 Mar 2017, 20:48
hm...
can't find the SHT3x in the Dev7 source either?
s4nder
#11 Post by s4nder » 31 Mar 2017, 19:16
Got the STH30 build from the playground source, but there where some build errors:
Wire/Wire.h: In member function 'void SHT3X::get()':
Wire/Wire.h:69:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, in
note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t)
It does compile however. Strange is that the values are quite high, is it in Celsius or Farenheit?
budda85
#12 Post by budda85 » 04 Apr 2017, 09:39
dzikus wrote: 11 Feb 2017, 11:07
It ist not so easy.
I become a lot of Errors :(
WARNUNG: Bibliothek LiquidCrystal_I2C behauptet auf [avr] Architektur(en) ausgeführt werden zu können und ist möglicherweise inkompatibel mit Ihrem derzeitigen Board, welches auf [esp8266] Architektur(en) ausgeführt wird.
In file included from C:\Users\Jan\Desktop\ESPEasy\ESPEasy.ino:227:0:
C:\Users\Jan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.h: In member function 'void SHT3X::get()':
C:\Users\Jan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.h:69:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int)
     uint8_t requestFrom(int, int);
C:\Users\Jan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.h:67:13: note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t)
     uint8_t requestFrom(uint8_t, uint8_t);
C:\Users\Jan\Documents\Arduino\libraries\IRremoteESP8266\IRDaikinESP.cpp: In member function 'void IRDaikinESP::send()':
C:\Users\Jan\Documents\Arduino\libraries\IRremoteESP8266\IRDaikinESP.cpp:19:11: error: 'class IRsend' has no member named 'sendDaikin'
   _irsend.sendDaikin(daikin);
Mehrere Bibliotheken wurden für "Servo.h" gefunden
 Benutzt: C:\Users\Jan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Servo
 Nicht benutzt: C:\Program Files (x86)\Arduino\libraries\Servo
exit status 1
Fehler beim Kompilieren für das Board WeMos D1 R2 & mini.
budda85
#13 Post by budda85 » 05 Apr 2017, 07:16
Ok, I'm sorry.
I used the wrong Arduino IDE Version.
Now its working perfect
beic
#14 Post by beic » 23 Apr 2017, 18:31
I have rewrite the Plugin for my personal usage, and it's working now on older releases/versions like R147 too!
Cheers
lucaberta
#15 Post by lucaberta » 24 Apr 2017, 00:28
beic wrote: 23 Apr 2017, 18:31 I have rewrite the Plugin for my personal usage, and it's working now on older releases/versions like R147 too!
amazing timing, as I have just finished soldering the SHT30 mini shield for my Wemos D1 and came on the forum looking for SHT30 support in both the v1 and v2 version of ESPEasy.
Do you have a Github repository, or do you have any other way to share the v1 plugin source so I can compile it in my R148?
Thanks, Luca
loboesp
#16 Post by loboesp » 24 Apr 2017, 16:38
Cheers
Can you share this? Thanks in advance.
Tbomek
#17 Post by Tbomek » 05 Mar 2018, 13:19
Hello. I need to read two sht30 on one wemos d1 mini. Does anyone have a plugin that can do it? The current plugin reads only one sht30 address at a time.
beic
#18 Post by beic » 05 Mar 2018, 13:50
Tbomek wrote: 05 Mar 2018, 13:19 Hello. I need to read two sht30 on one wemos d1 mini. Does anyone have a plugin that can do it? The current plugin reads only one sht30 address at a time.
It's already included, see on GitHub:
https://github.com/letscontrolit/ESPEas ... _SHT3x.ino
Tbomek
#19 Post by Tbomek » 05 Mar 2018, 14:01
Does not have. I use the latest version. It does not work with two SHT30 on wemos d1 mini.
The plugin always reads the last 0x45, it does not see 0x44.
beic
#20 Post by beic » 05 Mar 2018, 14:05
Tbomek wrote: 05 Mar 2018, 14:01 Does not have. I use the latest version. It does not work with two SHT30 on wemos d1 mini.
Yes, because I made it, so, did you select the correct addresses like for one 0x44 and for the second one 0x45?, also don't forget to short juper on one of the shield board.
Tbomek
#21 Post by Tbomek » 05 Mar 2018, 14:36
Yes, I changed jupers on the shield and chose different addresses in the tasks.
{"System":{
"Build": 20100,
"Unit": 1,
"Local time": 2018-03-05 14:34:45,
"Uptime": 1,
"Free RAM": 18056
"Sensors":[
"TaskName": "SHT30_0x44",
"house T": 6.52,
"house H": 49.81
"TaskName": "SHT30_0x45",
"OutDor T": 6.48,
"OutDor H": 49.78
0x45 is outside
0x44 it's inside my house where it's 21 degrees
0x44 it shows the same as 0x45
see my photos https://photos.app.goo.gl/mMjx1g0ZylR24dzX2
beic
#22 Post by beic » 05 Mar 2018, 15:31
Tbomek wrote: 05 Mar 2018, 14:36 see my photos https://photos.app.goo.gl/mMjx1g0ZylR24dzX2
Gonna see what is happening there...
Tbomek
#23 Post by Tbomek » 12 Mar 2018, 18:38
Hello, do you have time to see it?
beic wrote: 05 Mar 2018, 15:31
beic
#24 Post by beic » 14 Mar 2018, 13:22
Tbomek wrote: 12 Mar 2018, 18:38 Hello, do you have time to see it?
PR was made on the GitHub, but not Merged yet, see https://github.com/letscontrolit/ESPEasy/pull/1081, majority of duplex Plugins have a same issue!
p.s. Please leave you post test feedback about current changes
Tbomek
#25 Post by Tbomek » 14 Mar 2018, 20:17
Thank you, it's much better. Now it reads two sensors separately. I check on "ESP_Easy_masy-20180314_dev_ESP8266_4096" a few days and I will give a report.
beic
#26 Post by beic » 14 Mar 2018, 20:22
Tbomek wrote: 14 Mar 2018, 20:17 Thank you, it's much better. Now it reads two sensors separately. I check on "ESP_Easy_masy-20180314_dev_ESP8266_4096" a few days and I will give a report.
Appreciated ;)
beic
#27 Post by beic » 16 Mar 2018, 15:57
Tbomek wrote: 14 Mar 2018, 20:17 I check on "ESP_Easy_masy-20180314_dev_ESP8266_4096" a few days and I will give a report.
There is a new firmware released with merged plugin!
Tbomek
#28 Post by Tbomek » 16 Mar 2018, 17:41
Great. I am glad that this problem has been solved.
beic
#29 Post by beic » 16 Mar 2018, 17:55
Tbomek wrote: 16 Mar 2018, 17:41 Great. I am glad that this problem has been solved.
Yeah, so, did you made any test? All working as expected now?!
Tbomek
#30 Post by Tbomek » 16 Mar 2018, 18:41
Yes, I tested on two wemos 1d mini. The first one is working in a recuperator in my home. After uploading the patch. Good temperature, bad reading humidity (jumps ~ 40% to ~ 95%). I exchanged wemos 1d for a second and then everything returned to normal.
Curiosity. I thought I had a damaged first wemos d1 min. I rewrote the patch and connected the STH30. Everything was back to normal. I assumed that it coincided with a circumstance, maybe some cables came in contact? Does not matter. It is important that it is already working. :)
Ps. I am sorry for my language. I hope you understood me. ;)
beic
#31 Post by beic » 16 Mar 2018, 18:45
Tbomek wrote: 16 Mar 2018, 18:41 Yes, I tested on two wemos 1d mini. The first one is working in a recuperator in my home. After uploading the patch. Good temperature, bad reading humidity (jumps ~ 40% to ~ 95%). I exchanged wemos 1d for a second and then everything returned to normal.
Glad that you solved all out! ;) And your language are just fine! 8-)
