My Meian Door contacts & motion detectors are not recognized by a Nodo shop 868MHz RFLink using RfLink 1.48 version.
I thought these devices were Visonic compatible.
Did I miss something ?
Meiantec 868Mhz devices
Re: Meiantec 868Mhz devices
Make a debug log and send that to me..
Here are instructions on how to do that:
http://www.rflink.nl/blog2/development
Thanks,
I attached a file with debug info for door contact and PIR.
Regards,
Regards,
- Meian 868 Devices Debug.zip
- (2.2 KiB) Downloaded 454 times
Any feedback ?
Does anyone have an idea of the problem.
As far as I know The meian MD 210R 868Mhz door contact is the same than the Atlantic's one which is supported by RFLink V1.48.
The debug info I get look strange as there is just an alternance of short and long pulse :
20;20;DEBUG;Pulses=223;Pulses(uSec)=2220,300,690,300,690,300,720,300,720,330,690,300,690,270,720,270,750,300,690,300,690,300,690,300,720,270,720,300,690,330,660,300,690,300,690,300,690,300,690,330,690,270,750,300,690,270,720,300,720,300,690,300,720,300,690,300,690,330,660,330,660,270,720,270,720,300,720,300,690,300,720,270,750,270,3900,270,720,330,690,300,690,300,720,330,690,300,720,330,690,300,690,270,750,270,720,300,720,270,720,300,690,300,720,300,720,300,720,330,660,300,690,300,690,300,690,300,690,270,720,300,720,270,720,300,690,270,750,300,690,270,720,270,720,330,660,330,690,300,720,300,720,300,720,300,690,300,690,300,3900,300,720,270,720,300,720,300,690,330,690,270,720,330,690,270,720,330,690,300,690,270,720,240,750,300,720,270,750,300,720,270,720,270,750,300,690,300,690,300,720,300,720,270,690,300,720,300,690,270,750,240,750,300,720,270,750,270,750,300,690,300,690,300,720,300,720,300,720,330,660,300,720,300,6990;
I wonder if my RFLink is working properly.
I'm having the same issue.
Know what, I'm happy to say this phone casino register uk is generous with info. There you can find any info you need. This is great, huh?
Same issue with Meian MD210 868 mhz
Did you find a solution ?
