GPIO not change state from rules
gdrak0
#1 Post by gdrak0 » 14 Mar 2018, 18:12
Hi All
I use nodemcu 8266 and ESPEasy v2.0-20180312.
I've made a thermostat through the rules and everything works normally except for the change in gpio.
on System#Boot do
// thermostat - default value at boot
 TaskValueSet 2,1,19
on UP#val do
 // Button - Up setpoint
 TaskValueSet 2,1,([thermostat#setpoint]+0.5)
 if [thermostat#setpoint]>30
 TaskValueSet 2,1,30
on DOWN#val do
 // Button  - down setpoint
 TaskValueSet 2,1,([thermostat#setpoint]-0.5)
 if [thermostat#setpoint]<15
 TaskValueSet 2,1,15
on sensor#Temperature do
 if [sensor#Temperature]>[thermostat#setpoint]
 GPIO,16,1
 if [sensor#Temperature]<[thermostat#setpoint]
 GPIO,16,0
The rule runs normally without any problems and I also see all commands running correctly through the console.
The problem is that there are no changes in the gpio,16,1 and gpio,16,0 commands.
I mean the voltage on this pin remains 0 but if I run from the browser this command (http://192.168.6.100/control?cmd=GPIO,16,1) the change is done correctly.
I have tried previous versions and other gpio but again without success.
There is something wrong or something that escapes me ??
Thank you.
Re: GPIO not change state from rules
#2 Post by grovkillen » 14 Mar 2018, 18:33
You have two sensor#Temperature which makes the rule parser not getting what to do. You need to have a else instead. Please study the wiki.
gdrak0
#3 Post by gdrak0 » 14 Mar 2018, 18:55
Some help if you want about it ...
#4 Post by grovkillen » 14 Mar 2018, 19:32
Have you looked at the wiki?
kimot
#5 Post by kimot » 14 Mar 2018, 23:16
instead of:
 GPIO,16,1
 GPIO,16,0
You can use only one "sensor#Temperature" event, not two
Use:
     GPIO,16,1
     GPIO,16,0
Or use timer and check temperature every minute or 5 minutes for example
gdrak0
#6 Post by gdrak0 » 15 Mar 2018, 10:58
Bingo !!
It works great.
Thank you for all..
