Hummm, so where is the - I'm a dork" section? :-)
Hi Gang,
I've got a problem ..... I have an ESP-12 made by WeMos and its a D1 Mini Module.
It's chugging away happily and I can see it inside on 192.168.x.x I also opened the post 80 on my router to let it out.
For whatever reason ... no joy !! I can't see it from outside, it IS port 80 right!? Any suggestions?
Cheers'
Dave
Cheers'
Dave
Re: Hummm, so where is the - I'm a dork" section? :-)
I would NOT expose it to the internet directly. Why do you want that?
Technically:
The "private" IP addresses like 192.168.xxx.yyy are "non-routeable" by definition.
Most usual routers, even home routers, follow these definitions.
It is possible to reach such an adress from the outside but that's a tricky thing and
needs some knowledge about routing and IP forwarding, adress translation and so on.
On top it needs a sophisticated router that can do this job.
I agree with grovkillen:
I'd never ever connect an ESP to the internet directly.
It's an unencrypted connection so everyone from outside is able to sniff
you data, including password.
A workaround to both, routing problems and encryption might be a VPN.
But describing that in detail is far beyond the scope of a forum post.
Here's a snap of two options in the router:
Cheers'
Dave
Cheers'
Dave
Oh it's not going to be out there permanently - its just for now for testing.
Eventually it'll feed a Pi and provide lovely trends and graphs!
It's just odd that it "seems" like the bugger can't get thru the router and I
have lots of stuff passing thru ! I've never run in to this before !?!
Cheers'
Dave
Cheers'
Dave
Besides if they hack it and discover the hot tub's temp - so be it (grin)
Cheers'
Dave
Cheers'
Dave
Port forward is the way to go then.
- budman1758
This is one of those times where a configurable web server port would come in very handy...
You can redirect any port from the outside to port 80 on the target unit.
Lets say that you use a dynamic dns service and connect to your.dns.com and have three different units that you want to expose to the internet. Then you can do it like this :
your.dns.com:50000 - - > router portforward 50000 to - - > 192.168.0.100:80
your.dns.com:50001 - - > router portforward 50001 to - - > 192.168.0.101:80
your.dns.com:50002 - - > router portforward 50002 to - - > 192.168.0.102:80
In post #4 you showed the IP list.
What I saw is that the last 2 lines have the same IP. HTTP.. + Hot Tub. Maybe this is the cause
They also have the same public port which actually IS the issue. The router has no way of knowing which rule to use when connecting from the outside to port 80. Furthermore, some ISPs block port 80, so using another port will solve both issues. Finally there is a source ip address. I don't know what exactly this means but I guess it probably only accepts connections from that address (which is a private address and would never be routed by the ISP)
Users browsing this forum: Bing [Bot] and 32 guests
