I would say 400 - 700 ppm = green
700 - 1400 = orange
1400+ = red.
MH-Z14 / MH-Z19 CO2 sensor
Re: MH-Z14 / MH-Z19 CO2 sensor
thats are my practical results, too.
Thank you
I wrote a short blog Post in my Blog, works fine.
https://blog.moneybag.de/fhem-luftquali ... asy-wemos/
Thank you
I recently received my MH-Z14a sensor, I want to use it to send CO2 values to my home automation system via MQTT.
When I got it, I first hooked it up to a arduino nano and the PWM example form this site: http://domoticx.com/arduino-co2-sensor-mh-z14/
It seemed to work, The red light was flashing every few seconds, and I got some plausible values.
I now want to do the same with on the ESP8266 ESP-12. When I use the same sketch, I got some odd values and the red light was not flashing. I thing the problem is that my ESP circuit is working on 3.3v, while the sensor requires 5v.
To overcome that problem, I tried using one of these as power supply for the sensor: http://www.mpja.com/images/30175-large.jpg , while keeping the 3.3v power supply for the ESP. Unfortunately the result stayed the same.
I then tried switching to UART instead of PWM, and used a simplified versiopn of this sketch to test it: https://github.com/bertrik/mhz19/blob/m ... 2meter.ino
Unfortunately, it seems that the command bool result = exchange_command(0x86, data, 3000); in that sketch always returns 0 for me.
Any idea where I'm going wrong?
Are you sure you set TX on the ESP to RX on the sensor and vice verse?
You could also try this sketch: (section with the UART implementation)
Thanks, it seems like that was actually the case, now that I switched the RX and TX wires, I am able to get some plausible output from the sensor.
Does anyone know by the way what type of the 7 pin connector is? it seems to be as JST connector, but not with the standard 2.54 pitch spacing.
Edit: Figured out that it's most likey a JST-SH connector with 1.0mm spacing.
I did get my MH-Z14a working with the calibration sample from s3030150. I combined it with some code to send the values with a ESP8266 over MQTT (I'm sending it to home assistant)
If anyone is interested: https://github.com/eriknl1982/esp8266_mh-z14a-mqtt
The only issue I'm now facing is that after a while (sometimes a few hours, sometimes a day) the sensor starts returning 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 as response. The only way to get back to normal values is by powering the sensor down and up again.
anyone else experiencing this?
You guy saved my life. It is now working.Barb232 wrote: ↑29 Mar 2018, 09:02 Finally, it works.
i downloaded the document
http://www.winsen-sensor.com/d/files/in ... ver1_0.pdf
And i tried the method 8a (manual calibration)
I soldered a button between GND and HD and pressed the button for 7 seconds
waited 20 min with open window
Results: values 395 ppm
Lets wait and see
photo follows
using espeasy
and how can i do that with a gpio LED rgb? rules
what value-ranges should i use?
/robin
I used a dupont cable to connect the 2 pins together for 7 seconds.
