ALLNET 4duino IoT WLAN ESP8266-UP-Relais - rx and tx to GPIO
i am new in this forum. I use about 20 sonoff S20 and 3 sonoff basic with espeasy. Now i flashed this device wkth the newest espeasy Mega version:
https://m.future-x.de/item/313635333639 ... 2gQAvD_BwE
It works very well. I switch my outdoor lamps with it. Now i want to use the Rx and Tx pins for GPIO. One for the bell-button, and one for a relais for the bell. But it wont work. No input or output is possible. Serial is switched of under advanced configuration. Is it possible, to adjust espeay, to work with the device?
In the atachment everything i get from the distributor.
- ALL_Relais.zip
- (2.98 MiB) Downloaded 223 times
- allnet.zip
- (92.59 KiB) Downloaded 226 times
Re: ALLNET 4duino IoT WLAN ESP8266-UP-Relais - rx and tx to GPIO
no chance, to get it work?
This docu i have also:
- 148814.zip
- (425.02 KiB) Downloaded 199 times
How do you connect the switch? Do you short it by putting GND to the pin?
I use GPIO 5 (SCL) for lightswitch. GPIO4 (SDA) for a led. Now i want to use GPIO 1 (Tx) for Bell-Button, and GPIO2 (Rx) for a relais for the bell.
Some pictures of my settings
- Screenshot_20180518-164902.png (84.87 KiB) Viewed 5636 times
Once more
- Screenshot_20180518-164922.png (81.04 KiB) Viewed 5632 times
So you have the gnd connected to the switch/button?
I tested it on GND (settings: normal switch) . The relais once on GND (settings: push botton active high) and on 3,3V (settings: push button active low). Nothing work.
Please take good pictures so I can see what you have done. If possible, use colors for the wires (black for GND etc) so I understand more.
It works
Relais i used was bad. To much power consumention. Switch works, too. Need to use "internal pullup"
Yes I'd recommend it to be sure to have the value high when the switch is NO.
Users browsing this forum: Bing [Bot] and 56 guests
