SOLVED! MP3 plugin & YX5300
mrwee
#1 Post by mrwee » 03 Jun 2018, 09:05
Just wondering if anyone has https://www.letscontrolit.com/wiki/index.php/MP3_player working? I've tried it on 'mega-20180524', connected RX on the YX5300 to TX on a D1 mini. Plugin configured to use GPIO-1 (D10), serial port disabled under 'Advanced'. SD card is FAT32 formatted with a couple of 1.mp3, 2.mp3, 3.mp3 files on it. I'm running the HTTP command shown in the example, but nothing happens :(.
Any ideas are very welcome!
Re: MP3 plugin & YX5300
#2 Post by grovkillen » 03 Jun 2018, 09:35
I've used it many times. I got both units no problem. Haven't used it with latest releases though.
#3 Post by grovkillen » 03 Jun 2018, 09:35
You should try an older version.
mrwee
#4 Post by mrwee » 03 Jun 2018, 11:34
grovkillen wrote: 03 Jun 2018, 09:35 You should try an older version.
Just to minimize troubleshooting, which version do you have it working on? (If I'm lucky, perhaps you also have a .bin file?)
#5 Post by grovkillen » 03 Jun 2018, 11:43
It was DEV10.
Domosapiens
#6 Post by Domosapiens » 03 Jun 2018, 21:35
This version is operational:
Firmware
Build 20100 - Mega (core 2_3_0)
GIT version mega-20180119
Plugins 70 [Normal] [Testing]
Anyhow ... you need the to use the "test" bin.
Did you?
mrwee
#7 Post by mrwee » 03 Jun 2018, 23:01
Yes, I did use the 'test' version and the plugin was available. But nothing happened when I executed the command. I'll see if I can compile the version you're referring to, unless I'm so lucky that you have a .bin file? ;)
#8 Post by grovkillen » 03 Jun 2018, 23:11
It's available on GitHub. Just look in the releases.
mrwee
#9 Post by mrwee » 10 Jun 2018, 17:41
I might be blind, but I can't find that plugin in the 'mega-20180119' TEST BIN. Trying to compile it myself, throws tons of errors...
Domosapiens
#10 Post by Domosapiens » 10 Jun 2018, 20:32
mrwee
https://we.tl/gnbPRYSC0l
1 file, 5.47 MB in total ・ Will be deleted on 17 June, 2018
mrwee
#11 Post by mrwee » 24 Jun 2018, 08:41
Thanks for your help guys. With the aid of verified versions, I discovered that the SD card was incompatible with the YX5300 player. I also found the LED on the player, which should light up when ready. Mine didn't :( .
Switching to another SD card made everything work :).
