Beginning on espeasy, I connected an Arduino to a Wemos (Espeasy) via the serial port.
So far no problem. I get the info on the Wesmos (visible in the log), I joined a capture logs.
Now I would like to display information from the arduino on an OLED SSD1306 screen, to make it simple in real time.
Unfortunately, I can not do it, at the same time I do not know if it's possible. Should not I put this info in a variable?
If someone has an idea…
Thank you
ESPEASY serial port info
- logs.jpg (153.21 KiB) Viewed 4706 times
Re: ESPEASY serial port info
You could use rules for that. The event trigger is in your case !Serial#Distance and to display the value on the display you use the corresponding OLED command and use this as your value [!Serial#Distance].
Or you could try and see if it's enough to use the value [!Serial#Distance] in the OLED setup page.
Thanks. I try it tonight.
but what is the command to send in the rules to the GPIO?
I try to use the value [!Serial#Distance] in the OLED setup page but it's not working.
You'll find that info on our wiki page. Come back here if you still struggle with it.
I can not do it in both cases.
On !Serial#Distance do
OLED,<5>,<5>,<[!Serial#Distance]>
OLED,5,5,[!Serial#Distance]
Sorry, but it's the same.
I don't understand. I try with a text and it's not working.
I can change the state of a LED
