ESPEasy Mega 2.0 and SDS011 sleep/wake time
Currently ESPEasy Mega 2.0-dev version has an option for SDS dust sensors to make them go sleep for certain amount of time. The sensor wakes up for 30 seconds and then goes to sleep for entered amount of time again and again. Would it be possible to add another text field, but this time for wake time? I would like to extend 30 seconds to 60, but this value is hardcoded. I think that 30 seconds is a little to short for PM 2.5/10 readouts to stabilise.
- budman1758
Re: ESPEasy Mega 2.0 and SDS011 sleep/wake time
You can post an issue on Github for this. Best place to start for feature requests such as this.
https://github.com/letscontrolit/ESPEasy/issues
Got it. Thank You.
Hello!
The Plugin actually uses the "Set working Period" of the SDS011 Module.
In this Module the 30 seconds are hardcoded. See the attached PDF on Chapter 5.
To do this in this Way, a Timer runs on the ESP-Easy and a second independent timer runs on the SDS.
They are not syncronized.
So the SDS wait in Sleepmode, wake up and start the Fan, after 30 seconds the SDS send Data.
But it in not shure, that the ESP-Easy read the Data, because the ESP-Plugin is at this Time inactive, maybe.
This is actually my Problem.
But I can not fix the Problem in the Plugin, I have not enough experience in this.
I think, the Problem can be solved in this way:
The Plugin don't use the "Working Period" of the SDS.
The Plugin use the direct Control of "Work" and "Sleep" Mode. See the attached PDF on Chapter 4.
In this Case there are no two unsynced Machines, and the Possibility to config the Fantime before Datasend is given too.
But I am new in Github and I dont know the Way to publish this issue on Github.
I can not attach the file, here the link:
https://cdn.sparkfun.com/assets/parts/1 ... l_V1.3.pdf
Excuse my english, my german is much better
Can you help me?
With regards, Axel
Can you help me?
With regards, Axel
also in the current MEGA implementation, the sleep is not stable.
The sensor does work for 30s but the following sleep is also just 30s independent from the time set in the plugin.
Does someone else also has this issue?
The sleep time you can set in the plugin is saved to the sensor itself.
So the sensor is then active for 30 seconds and will sleep for the set time.
N.B. this is the sleep time of the sensor page, not the sleep/wake time of deepsleep setting of ESPeasy.
It is working very stable here since the last day of 2017, when I wanted to measure the impact of the fireworks
For how many seconds/minutes do you let your device sleep? The sds011 can clogg up when it runs long periods Im curious what would be best practice for nice results without any periodic maintananceTD-er wrote: ↑09 Apr 2018, 23:05 The sleep time you can set in the plugin is saved to the sensor itself.
Mine runs with the "Sleep time" set to 5 minutes.water wrote: ↑30 Jul 2018, 23:41For how many seconds/minutes do you let your device sleep? The sds011 can clogg up when it runs long periods Im curious what would be best practice for nice results without any periodic maintananceTD-er wrote: ↑09 Apr 2018, 23:05 The sleep time you can set in the plugin is saved to the sensor itself.
And it detected the BBQ just fine, running for 7 months now. It has endured below -10C and Above +35C just fine.
Thanks, and what is your setting at Interval?TD-er wrote: ↑01 Aug 2018, 21:59Mine runs with the "Sleep time" set to 5 minutes.water wrote: ↑30 Jul 2018, 23:41For how many seconds/minutes do you let your device sleep? The sds011 can clogg up when it runs long periods Im curious what would be best practice for nice results without any periodic maintananceTD-er wrote: ↑09 Apr 2018, 23:05 The sleep time you can set in the plugin is saved to the sensor itself.
For some reason I receive every 5 minutes data, but sometimes also after 10 minutes.
The interval can be low like 30 seconds.
The sensor will only give samples when a new one is captured.
