I'm trying to see if I can turn off the WiFi to reduce power usage at night time, using the following:
On System#Boot do
gpio,12,0
WifiConnect
on Clock#Time=All,06:00 do
reboot
On wifioff do
delay 8000
WifiDisconnect
on Clock#Time=All,17:50 do
WifiConnect
on Clock#Time=All,22:00 do
WifiDisconnect
This is on a NodeMCU v3, which i've just installed in my car to trigger an alarm siren (either by WiFi or by proximity sensor) to deter young children playing near it, throwing things at it, scraping bike pedals down the side of it. I plan to add more functionality later.......
It's taking 35-40mA and i'm hoping that WiFi off will save a few more mA.
BUT, what is happening is I turn the WiFi off by the above (direct command or a timer), it disconnects as it should, but then 60s later it's back on again.
Any idea about this problem?
Wifidisconnect command
Re: Wifidisconnect command
There is a wifi check function to perform a reconnect (and wifi reset).
This function should be made aware the wifi is off intentional.
So this is currently not possible to achieve, without change in software.
Can you make an issue for this on Github?
Users browsing this forum: No registered users and 98 guests
