How to read the status of relays from Domoticz during booting ESP Easy ? and set the relay in ESP Easy ?
Best Regards,
Robert
Relay recovery last state after power failure
Re: Relay recovery last state after power failure
you must use MQTT and use the message persistance features in order to do this (I have this feature in some of my modules even thou I don't use Domoticz)
To clarify, papperone says you must activate the "MQTT retain" feature on the advanced tab.
yes indeed, thanks for clarification, and as well in all devices that can send that message!
(in my case I can toggle a switch from the GUI which runs on a RaspberryPi and those message must be sent as well with the retain activated else the setup will not work properly!)
