Tank water level with MS5540-CM
Sejcek1
#1 Post by Sejcek1 » 08 Sep 2018, 16:25
Hi all,
Is there support for sensor MS5540-CM planned? It is quite cheap waterproof pressure sensor.
https://www.ebay.com/sch/i.html?_from=R ... M&_sacat=0
It seems it might be good for projects where you need to monitor the amount of water or other fluid (height / pressure) and, for example, drive the garden irrigation automation. Certainly, such a possibility would apply to many other people. Could anybody will be able to write a plugin for this sensor? I found some script for Arduino, but I can not know how to write it for ESPEasy:
https://gist.github.com/hephaestus9/daf ... 720e0e3431
Best Regards!
Sejcek1
Re: Tank water level with MS5540-CM
#2 Post by grovkillen » 08 Sep 2018, 16:33
Looks like a good sensor. You should add it as a feature request on GitHub.
HomeJCL
#3 Post by HomeJCL » 08 Sep 2018, 19:32
Looks good
But how to implement ? how to rig this to existing piping or water tanks ?
By the way, for level ... a barometer won’t be of much use.
Belgium and land of ESP ... counting :D
Domosapiens
#4 Post by Domosapiens » 09 Sep 2018, 21:11
How about the supported Ultrasonic HC-SR04
https://www.letscontrolit.com/wiki/index.php/HC-SR04
Waterproof:
https://www.aliexpress.com/item/Integra ... 90912.html
(not sure if they have the same interface towards ESPEasy)
Sejcek1
#5 Post by Sejcek1 » 14 Sep 2018, 02:00
@HomeJCL: Just put it to the lowest place of the tank/pipe. Water/hydrostatic pressure is equal to water height so barometer should be useful (sure, only for atmospheric pressure tanks). It should be easy to convert pressure to water height.
@Domosapiens: You can measure up to 100m water level in narrow borehole within this sensor and sensitivity looks quite good.
https://www.youtube.com/watch?v=g_7txTdy-tg
HomeJCL
#6 Post by HomeJCL » 14 Sep 2018, 04:16
There are several types of this sensor
The link goes to a range of 10 ... 1100 mbar
with 100m waterproof spec ! Means over pressure capability nothing todo with measuring range.
Anyway if you use the linked sensor, (abs press sensor barometer), you need a second one as reference (for measuring atmospheric pressure) to be substracted from the level pressure
Eg Pabs 1023 mbarabs. Measurement of level 1089mbarabs
Level 1089-1023=66mbarabs ~ 660mm level
With sensor max range 1100, this summer where I live, we had max Patm 1037 leaves us a max useful level on that day of 630mm water !!!
Recap :
read carefully spec sheet !
need 2 pces to measure level or anyway you’ll need a Pabs reference to calculate level from vessel. Needs additional “programming” not much but I’m lazy
So you simplify by using same type but looking for a gauge pressure type and not absolute pressure.
But then we are back at square 1, expensive, difficulty of mounting, exposed circuit and risk of leakage !
JSNxxxxx sensor costs around 7 $US works up to 4-5m and does mount in no time and no risk of leakage.
KISS ... that is ESP Easy philosophy
Users browsing this forum: Google [Bot] and 62 guests
