Help With Rules
Re: Help With Rules
yep that was the problem with SW. i change it to active low.
so now sw1 change the status 1 to 0 and so on...
but no relay toggle.
also when i send setRelay01=0 or 1 the relay change status and sw1 stays at previous state without change.
here is the log:
1760467: EVENT: sw1#state=1.00
1760477: ACT : Event,toggleRelay01
1760532: Command: event
1760532: EVENT: toggleRelay01
1760555: ACT : Event,setRelay01=1
1760587: Command: event
1760588: EVENT: setRelay01=1
1760605: ACT : GPIO,0,1
1760607: SW : GPIO 0 Set to 1
1772041: WD : Uptime 30 ConnectFailures 0 FreeMem 19728
1774067: EVENT: sw1#state=0.00
1774076: ACT : Event,toggleRelay01
1774129: Command: event
1774130: EVENT: toggleRelay01
1774153: ACT : Event,setRelay01=1
1774187: Command: event
1774188: EVENT: setRelay01=1
1774205: ACT : GPIO,0,1
1774210: SW : GPIO 0 Set to 1
2124325: EVENT: setRelay01=0
2124342: ACT : GPIO,0,0
2124344: SW : GPIO 0 Set to 0
2132041: WD : Uptime 36 ConnectFailures 0 FreeMem 19728
2134826: EVENT: setRelay01=1
2134843: ACT : GPIO,0,1
2134845: SW : GPIO 0 Set to 1
2134920: SW : Switch state 1 Output value 0
2134923: EVENT: Relay01#state=0.00
here is the log:
Re: Help With Rules
You don't really need to care about the switch's state do you? It's only acting as a event trigger. No matter if it change from 1->0 or 0->1
But as for the relay not toggling. What's the GPIO for it, is it 0 or 12?
Re: Help With Rules
GPIO 0 is the relay.
gpio 12 is the sw.
for now i don't nee the state of the sw as it will always be as the state of the relay so..i
gpio 12 is the sw.
Re: Help With Rules
And sending a GPIO,0,1 or GPIO,0,1 makes the relay turn on/off?
The log is showing me that the rule is working as intended. I'm really at the wits end here.
Re: Help With Rules
yes im sending via http://10.0.80.108/control?cmd=GPIO,0,0 or 0,1 and the relay toggle.
also via mqtt command with payload":"event,setRelay01=1/0
Re: Help With Rules
So it's only the "toggleRelay" that is not working, or only semi-working?potzkiin wrote: ↑12 Sep 2018, 12:44 yes im sending via http://10.0.80.108/control?cmd=GPIO,0,0 or 0,1 and the relay toggle.
Re: Help With Rules
Would you mind getting a "webdump" (use my app) and send the zip file to me? I can send you the URL for where to upload the zip if you are willing to let me test it on a unit here.grovkillen wrote: ↑12 Sep 2018, 12:53So it's only the "toggleRelay" that is not working, or only semi-working?potzkiin wrote: ↑12 Sep 2018, 12:44 yes im sending via http://10.0.80.108/control?cmd=GPIO,0,0 or 0,1 and the relay toggle.
Re: Help With Rules
the relay respond to 1 and 0 with mqtt and http command.
the mqtt event,toggleRelay01,not working.
the SW1 wont toggle the relay.
Re: Help With Rules
I cannot do much more for you sir. It's a guessing game right now.
Re: Help With Rules
ill send you a PM with the DOWNLOAD link.
Re: Help With Rules
Okay, I loaded your settings and you have internal pull-up and inverted logic activated on the relay. Remove those!
Re: Help With Rules
Thanks for all the help!!!!!!!!!
now it is working great!!!!
here is all the configuration so everyone can use it ...
on System#Boot do
gpio,0,1 // Prevent relay turning on during boot
On sw1#state Do
Event,toggleRelay01
EndOn
On toggleRelay01 Do
if [Relay01#state]=0
Event,setRelay01=1
Event,setRelay01=0
EndOn
On setRelay01 Do
GPIO,0,%eventvalue%
EndOn
- sw1.jpg (85.15 KiB) Viewed 5625 times
- mqtt.jpg (33.5 KiB) Viewed 5627 times
- relay01.jpg (83.27 KiB) Viewed 5627 times
- sw1.jpg (85.15 KiB) Viewed 5627 times
- devices
- devices.jpg (62.34 KiB) Viewed 5628 times
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 36 guests
