So i followed the guides at https://www.letscontrolit.com/wiki/inde ... Platformio, https://www.letscontrolit.com/wiki/inde ... ith_github, https://www.letscontrolit.com/wiki/inde ... platformio I am running on Windows 10 Professional.
That gave me an environment that does a full PIO Build in about 15 minutes, and a normal_ESP8266_4096 (Which i gather would be the proper one for Wemos D1 Mini Pro, right?) in about 15 seconds.
I see a few warnings, about unused/redeclared variables, and I assume those are normal.
Then i copied _Pxxx_PluginTemplate.ino to _P217_ACS712AC.ino (I saw on the playground that I should use unique values between 100-199, but i also saw "used the next available one", which appears to be 217.
Peeking in _P002_ADC.ino i set out to modify my file to do nothing but initialize
//#include section
//include libraries here. For example:
//#include <LiquidCrystal_I2C.h>
//uncomment one of the following as needed
//#ifdef PLUGIN_BUILD_DEVELOPMENT
//#ifdef PLUGIN_BUILD_TESTING
#define PLUGIN_217
#define PLUGIN_ID_217 217 //plugin id
#define PLUGIN_NAME_217 "Energy Meter ACS712 AC" //"Plugin Name" is what will be dislpayed in the selection list
#define PLUGIN_VALUENAME1_217 "Ampere (RMS)" //variable output of the plugin. The label is in quotation marks
//#define PLUGIN_VALUENAME2_xxx "output2" //multiple outputs are supported
//#define PLUGIN_xxx_DEBUG false //set to true for extra log info in the debug
PIN/port configuration is stored in the following:
Settings.TaskDevicePin1[event->TaskIndex] - The first GPIO pin selected within the task
Settings.TaskDevicePin2[event->TaskIndex] - The second GPIO pin selected within the task
Settings.TaskDevicePin3[event->TaskIndex] - The third GPIO pin selected within the task
Settings.TaskDevicePort[event->TaskIndex] - The port in case the device has multiple in/out pins
Custom configuration is stored in the following:
Settings.TaskDevicePluginConfig[event->TaskIndex][x]
x can be between 1 - 8 and can store values between -32767 - 32768 (16 bit)
//A plugin has to implement the following function
boolean Plugin_217(byte function, struct EventStruct *event, String& string)
//function: reason the plugin was called
//event: ??add description here??
// string: ??add description here??
boolean success = false;
switch (function)
case PLUGIN_DEVICE_ADD:
//This case defines the device characteristics, edit appropriately
Device[++deviceCount].Number = PLUGIN_ID_217;
Device[deviceCount].Type = DEVICE_TYPE_ANALOG; //how the device is connected
Device[deviceCount].VType = SENSOR_TYPE_SINGLE; //type of value the plugin will return, used only for Domoticz
Device[deviceCount].FormulaOption = true;
Device[deviceCount].ValueCount = 1; //number of output variables. The value should match the number of keys PLUGIN_VALUENAME1_xxx
Device[deviceCount].TimerOptional = true;
Device[deviceCount].GlobalSyncOption = true;
Device[deviceCount].DecimalsOnly = true;
case PLUGIN_GET_DEVICENAME:
//return the device name
string = F(PLUGIN_NAME_217);
//called when the user opens the module configuration page
//it allows to add a new row for each output variable of the plugin
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_217));
case PLUGIN_WEBFORM_LOAD:
//this case defines what should be displayed on the web form, when this plugin is selected
//The user's selection will be stored in
//Settings.TaskDevicePluginConfig[event->TaskIndex][x] (custom configuration)
// Make sure not to append data to the string variable in this PLUGIN_WEBFORM_LOAD call.
// This has changed, so now use the appropriate functions to write directly to the Streaming
// WebServer. This takes much less memory and is faster.
// There will be an error in the web interface if something is added to the "string" variable.
//Use any of the following (defined at WebServer.ino):
//addFormNote(F("not editable text added here"));
To add some html, which cannot be done in the existing functions, add it in the following way:
addHtml(F("<TR><TD>Analog Pin:<TD>"));
For strings, always use the F() macro, which stores the string in flash, not in memory.
//String dropdown[5] = { F("option1"), F("option2"), F("option3"), F("option4")};
//addFormSelector(string, F("drop-down menu"), F("plugin_xxx_displtype"), 4, dropdown, NULL, Settings.TaskDevicePluginConfig[event->TaskIndex][0]);
//number selection (min-value - max-value)
addFormNumericBox(string, F("description"), F("plugin_xxx_description"), Settings.TaskDevicePluginConfig[event->TaskIndex][1], min-value, max-value);
//after the form has been loaded, set success and break
success = true;
case PLUGIN_WEBFORM_SAVE:
//this case defines the code to be executed when the form is submitted
//the plugin settings should be saved to Settings.TaskDevicePluginConfig[event->TaskIndex][x]
//ping configuration should be read from Settings.TaskDevicePin1[event->TaskIndex] and stored
//after the form has been saved successfuly, set success and break
success = true;
case PLUGIN_INIT:
//this case defines code to be executed when the plugin is initialised
//after the plugin has been initialised successfuly, set success and break
success = true;
case PLUGIN_READ:
//code to be executed to read data
//It is executed according to the delay configured on the device configuration page, only once
//after the plugin has read data successfuly, set success and break
success = true;
case PLUGIN_WRITE:
//this case defines code to be executed when the plugin executes an action (command).
//Commands can be accessed via rules or via http.
//As an example, http://192.168.1.12//control?cmd=dothis
//implies that there exists the comamnd "dothis"
if (plugin_not_initialised)
//parse string to extract the command
String tmpString = string;
if (argIndex)
tmpString = tmpString.substring(0, argIndex);
String tmpStr = string;
int comma1 = tmpStr.indexOf(',');
if (tmpString.equalsIgnoreCase(F("dothis"))) {
//do something
success = true; //set to true only if plugin has executed a command successfully
case PLUGIN_EXIT:
//perform cleanup tasks here. For example, free memory
case PLUGIN_ONCE_A_SECOND:
//code to be executed once a second. Tasks which do not require fast response can be added here
success = true;
case PLUGIN_TEN_PER_SECOND:
//code to be executed 10 times per second. Tasks which require fast response can be added here
//be careful on what is added here. Heavy processing will result in slowing the module down!
success = true;
} // switch
return success;
} //function
//implement plugin specific procedures and functions here
void p217_do_sth_useful()
//code
C:/Users/j2/Documents/GitHub/ESPEasy/src/_P217_ACS712AC.ino:197:51: note: in expansion of macro 'F'
C:/Users/j2/Documents/GitHub/ESPEasy/src/_P217_ACS712AC.ino:289:11: error: 'plugin_not_initialised' was not declared in this scope
C:/Users/j2/Documents/GitHub/ESPEasy/src/_P217_ACS712AC.ino:309:11: warning: unused variable 'comma1' [-Wunused-variable]
*** [.pioenvs\normal_ESP8266_4096\src\ESPEasy.ino.cpp.o] Error 1
[ERROR] Took 7.91 seconds
Environment normal_ESP8266_4096 [ERROR]
[ERROR] Took 7.92 seconds
[SUMMARY]
Environment esp-wrover-kit_test_1M8_partition [SKIP]
Environment esp32dev [SKIP]
Environment esp32test_1M8_partition [SKIP]
Environment normal_ESP8266_1024 [SKIP]
Environment normal_ESP8285_1024 [SKIP]
Environment normal_WROOM02_2048 [SKIP]
Environment normal_IR_ESP8266_4096 [SKIP]
Environment test_ESP8266_1024 [SKIP]
Environment test_ESP8285_1024 [SKIP]
Environment test_WROOM02_2048 [SKIP]
Environment test_ESP8266_4096 [SKIP]
Environment test_ESP8266_4096_VCC [SKIP]
Environment dev_ESP8266_1024 [SKIP]
Environment dev_ESP8285_1024 [SKIP]
Environment dev_WROOM02_2048 [SKIP]
Environment dev_ESP8266_4096 [SKIP]
Environment dev_ESP8266PUYA_1024 [SKIP]
Environment dev_ESP8266PUYA_1024_VCC [SKIP]
Environment hard_SONOFF_POW [SKIP]
Environment hard_SONOFF_POW_R2 [SKIP]
Environment hard_Shelly_1 [SKIP]
Environment hard_Ventus_W266 [SKIP]
