Interprete HTTP Server answer
Pre-ESPEasy I have built a time switch for my old house heating using an ESP32, manageable using a Webinterface. I would like to extend the webinterface with a few lines of code to respond to a resquest of ESPEasy concerning the status of the relay.
Question: is it possible to use the sendtohttp command for interpreting the answer of the server? Means: from ESPEasy I send somewhat like "http://xxx.xxx.xxx.xxx/S" to get an answer however formatted to trigger an event.
pi@raspberrypi:~ $ man woman
No manual entry for woman
pi@raspberrypi:~ $
Re: Interprete HTTP Server answer
Using rules and custom events and you can have the unit respond to any incoming commands.
So, if I fire out of the rules of my ESPEasy device the request "http://xxx.xxx.xxx.xxx/S" the answer of my Webinterface of the timer "control?cmd=event,State=1" will be interpreted correctly by ESPEasy and fire an event named "State" within the ESPEasy? Or has the server to answer "/control?cmd=event,State=1"?
[edit]
Mark: the requesting device shall be the ESPEasy, the responding device shall be the webinterface of the timer towards the ESPEasy. And ESPEasy shall interprete the answer of the server and act using rules.
[/edit]
[edit]
[/edit]
pi@raspberrypi:~ $
Yes that should be fine
Thank you for encouraging me, this is exactly the answer I was waiting for. I don't want to disassemble my house heating - not in end of october - for reprogramming my stable diy time switch ending in an endless circle of try and error.
I am using inside of my Arduino-routine the function "client.print(...)". Please, precise, do I have to print leading slash or no slash? Or doesn't matter?
pi@raspberrypi:~ $
I believe that you should use the leading front slash to get the unit interpret it since it'll be sent to the correct function that way
Nope, it does nothing.
ESPEasy:
Arduino diy Time Switch:
Log ESPEasy:
Serial log Time Switch (logging minimized info):
I'm doing somethin wrong, but I don't know what and where. Time switch disassembled, heating off, house cold, I'm at my end. Pls help.
ESPEasy:
on System#Boot do
timerSet,1,10
on Rules#Timer=1 do
SendToHTTP 192.168.101.91,80,/S
timerSet,1,10
on HeizStatus do
// do whatever with %eventvalue%
while (client.connected()) { // loop while the client's connected
else if (currentLine.endsWith("GET /S")) {
int LevelCheck = digitalRead(RELAY_PIN);
if (LevelCheck == HIGH){
client.print("/control?cmd=event,HeizStatus=1");
else{
client.print("/control?cmd=event,HeizStatus=0");
client.println();
// break out of the while loop:
client.stop();
client.stop();
1413792: EVENT: Rules#Timer=1
1413876: ACT : SendToHTTP 192.168.101.91,80,/S
1413887: ACT : timerSet,1,10
1413940: Command: sendtohttp
1415003: Timeout while reading input data!
New Client.
GET /S
pi@raspberrypi:~ $
Send a HTTP requests upon the call but maybe wait a second before doing it?
OK, a lot of try&error, still no success.
Rules ESPEasy:
Code Time Switch Arduino:
Log ESPEasy:
Serial Log Time Switch at call from ESPEasy:
Serial Log Time Switch Entering the url "192.168.101.91/S" in Firefox:
Firefox shows:
The request of ESPEasy is received by the server.
The server responds with the correct string, Firefox is able to display it.
The serial log of the time switch tells me by "Connection: close" that the ESPEasy even is not further interested staying in connection. So its not possible to receive and interpret a server response because ESPEasy doesn't wait for an answer, isn't it?
Rules ESPEasy:
on System#Boot do
timerSet,1,60
on Rules#Timer=1 do
timerSet,1,60
on HeizStatus=1 do
NEXTION,page0.r0.bco=65217
on HeizStatus=0 do
NEXTION,page0.r0.bco=50712
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html;charset=UTF-8");
client.println();
else{
client.println();
1011795: EVENT: Rules#Timer=1
1011878: ACT : SendToHTTP 192.168.101.91,80,/S
1011889: ACT : timerSet,1,60
1011946: Command: sendtohttp
1012163: Command: timerset
New Client.
GET /S HTTP/1.1
Host: 192.168.101.91
User-Agent: ESP Easy/20102/Oct 8 2018 02:22:21
Connection: close
New Client.
GET /S HTTP/1.1
User-Agent: Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:63.0) Gecko/20100101 Firefox/63.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: de,en-US;q=0.7,en;q=0.3
Accept-Encoding: gzip, deflate
Connection: keep-alive
Upgrade-Insecure-Requests: 1
pi@raspberrypi:~ $
OK, meanwhile I am able to answer my question by myself.
No. The ESPEasy doesn't care about anything answered to its sendtohttp.
The only way I have figured out to get status information from a non-ESPEasy-device is to initiate a procedure on the server of sending its own http-request towards the ESPEasy as an answer. Not the smartest way, but works finally.
What a pity that I had to try out this way by following wrong informations.
pi@raspberrypi:~ $
Sorry for misunderstanding you and thus giving you wrong info.
