espeasy + domoticz to dimmer light
megamarco83
#1 Post by megamarco83 » 17 Oct 2018, 12:22
Hi, i would have a nodemcu, with espeasy firmware and i would like to control and dimmer a light that is also controlled/dimmered by domoticz
is it possible?
for dimmer the light "phisically" i can use a rotary encoder connected to nodemcu and in espeasy inser a device as rotary encoder.
for connection of the light i can use this:
https://robotdyn.com/ac-light-dimmer-mo ... -110v.html
https://arduinodiy.wordpress.com/2018/0 ... -via-mqtt/
but what kind of device i need to use in espeasy to control it?
and how can menage the control/dimmering the light using domoticz<->espeasy?
thanks
Re: espeasy + domoticz to dimmer light
#2 Post by grovkillen » 17 Oct 2018, 12:25
It seems to be controlled using PWM level.
megamarco83
#3 Post by megamarco83 » 17 Oct 2018, 14:00
but there are two pin: pwm and zero crossing
how to menage the zero crossing??
megamarco83
#4 Post by megamarco83 » 19 Oct 2018, 09:45
mmm...no one that used espeasy and domoticz to dimmer a light? :)
kimot
#5 Post by kimot » 19 Oct 2018, 20:26
ESPeasy to Domoticz:
Use SendToHTTP using JSON API:
Set a dimmable light to a certain level
/json.htm?type=command&param=switchlight&idx=99&switchcmd=Set%20Level&level=6
Some lights have 100 dim levels (like zwave and others), other hardware (kaku/lightwaverf) have other ranges like 16/32
Level should be the dim level (not percentage), like 0-16 or 0-100 depending on the hardware used
When the light is off, it will be turned on
"status" : "OK",
"title" : "SwitchLight"
Domoticz to ESPeasy:
Use LUA script on Domoticz and event on ESPeasy
Inspiration:
http://www.domoticz.com/forum/viewtopic.php?t=21454
megamarco83
#6 Post by megamarco83 » 08 Nov 2018, 01:09
kimot wrote: 19 Oct 2018, 20:26 ESPeasy to Domoticz:
"status" : "OK",
Inspiration:
today is arrived this one:
i connect PWN pin with GPIO 13 on nodemcu with espeasy
i set task1 as switch (normal switch) and send to controller idx of domoticz dummy device
but now if i simply use the http command i'm not able to dimmer the light (i connect an old tungstene light ) it could be only on or off
i use:
http://192.168.0.154/control?cmd=pwm,13,0
http://192.168.0.154/control?cmd=pwm,13,100
http://192.168.0.154/control?cmd=pwm,13,500
http://192.168.0.154/control?cmd=pwm,13,900
but i can not dimmer
should i use also the zero-crossing ping? how to set with espeasy?
thanks
Meek
#7 Post by Meek » 09 Nov 2018, 20:01
With that module, for effectively dim your lights, you would need a logic controller to detect the zero crsossing and fire up the output (triac?) at the right time.
I happen to develop such Wi-Fi enabled dimmer and I’m using an ESP12 for Wi-Fi communications and other control “stuff” and a dedicated AVR to do the zero crossing and firing up the triac.
Domosapiens
#8 Post by Domosapiens » 10 Nov 2018, 10:00
Looks very professional ..Meek.
Users browsing this forum: No registered users and 66 guests
