Nextion display plugin
Moderators: Voyager, BertB, rtenklooster, Stuntteam, grovkillen, TD-er
Wiki
Re: Nextion display plugin
#451 Post by Wiki » 21 Nov 2018, 21:51
Which speed? Default setting of the Nextion display as well as the Nextion plugin is set to 9600.
To use 115200 baud I have added to the preinitialize event of page0 "baud=115200"
If you do so, you have to change the baud rate in your Wemos Devices Nextion from 9600 to 115200.
frank
#452 Post by frank » 25 Nov 2018, 13:03
I want to order a Nextion display so i can use it on my BBQ controller. My question is does this plugin also works with the improved nextion display??
#453 Post by ThomasB » 25 Nov 2018, 18:11
I have confirmed compatibility with the enhanced version. My evaluation used a NX4024K032-011.
frank
#454 Post by frank » 25 Nov 2018, 18:24
ThomasB wrote:
25 Nov 2018, 18:11
great thx
waspie
#455 Post by waspie » 10 Dec 2018, 03:51
I haven't updated my ESPs running my nextions for a long time since they were working ok. I used a recent release and now a ton of stuff isn't working right
how do I sent commands to the nextion now?
it used to be just as simple as
nextion,dim=5
but that no longer is the case, how do i do this now?
tried NEXTION,
Nextion
nextion.
nothing works.
plugin is receiving button presses
***Edit*** it's the name of the task now, in my case "lr"
You guys could make a note of that?
#456 Post by ThomasB » 10 Dec 2018, 05:43
I tested the latest version (mega-20181207) and no issues were observed.
If your nextion device is named lr then the command used in your example would need to be
lr,dim=5
homerruma
#457 Post by homerruma » 10 Jan 2019, 14:28
waspie wrote:
25 Jul 2018, 18:03
to take advantage of H/W serial using the pin swap option it needs to be wired like this, correct?
If this is ok then the scheme is on https://www.letscontrolit.com/wiki/inde ... le=Nextion is not good.
This scheme shows that D7 (RXD2) na Nodemcu connected with NEXTION RX.
Wiki
#458 Post by Wiki » 10 Jan 2019, 16:52
RXD2 has to be connected to TX Nextion, TXD2 to RX Nextion.
I don't use a transistor due to the fact that the signals of the Nextion are 3.3V.
#459 Post by ThomasB » 10 Jan 2019, 17:10
@homerruma: Thank you for reporting the error. The image has been corrected.
@wiki: Nextion and ESP8266 are indeed 3.3V devices. But the transistor is not intended to convert the logic level. It is a buffer that is used to ensure that the ESP8266 can boot-up. Without it there is a strong chance the ESP8266 will hang on a reset.
homerruma
#460 Post by homerruma » 10 Jan 2019, 18:28
As I see on the link https://www.letscontrolit.com/wiki/inde ... le=Nextion the image is not corrected.
Still stands RX Nodemcu at RX Nektion.
Imagenextion2 by homerruma3, on Flickr
Wiki
#461 Post by Wiki » 10 Jan 2019, 20:50
ThomasB wrote:
10 Jan 2019, 17:10
....But the transistor is not intended to convert the logic level. It is a buffer that is used to ensure that the ESP8266 can boot-up. Without it there is a strong chance the ESP8266 will hang on a reset.
Oh yes, you are right, now I remember.
Sometimes there are some benefits in the procedure first think before write. Thanks for the reminder...
#462 Post by ThomasB » 11 Jan 2019, 00:01
Hmm, I see the correct drawing in my browser.
Try refreshing your browser cache to regenerate the Nextion Wiki page. Usually the F5 key will do a refresh (works in FireFox). A refresh should populate the recently uploaded image.
homerruma
#463 Post by homerruma » 11 Jan 2019, 00:13
I've refreshed the page. Now I closed it and reopened it, I can not see the changes.
Definitely everything is old.
Ask the third party to confirm.
#464 Post by ThomasB » 11 Jan 2019, 00:38
Hopefully someone in the audience can confirm the wiki page has the new drawing.
I retested the Nextion wiki page using three different WIN10 PC workstations. And I viewed the page using FF, Edge, IE, and chrome browsers. They all show the latest image.
Here's a screenshot:
I have an idea. Try this test: Go to this wiki image folder: https://www.letscontrolit.com/wiki/inde ... r1_450.jpg
You will see two images in the file history. The original (depreciated) July-30-2018 and the corrected image from today, Jan-10-2019. The corrected image is the one that is targeted by the Nextion Wiki page. If you don't see both images then that would indicate that there is a wiki server cache issue; Check again in a few hours.
homerruma
#465 Post by homerruma » 11 Jan 2019, 00:56
This time, Chrome vs Firefox
Imagechrome vs firefox by homerruma3, on Flickr
homerruma
#466 Post by homerruma » 11 Jan 2019, 00:59
Yes, it's corrected
Imagenextion file history by homerruma3, on Flickr
#467 Post by ThomasB » 11 Jan 2019, 01:08
To refresh chrome's cache you should hold Ctrl and press F5.
https://www.getfilecloud.com/blog/2015/ ... DfeN817kaY
homerruma
#468 Post by homerruma » 11 Jan 2019, 12:26
Thank you.
Users browsing this forum: Google [Bot] and 2 guests
