I did a clean install of the latest built on a Wemos D1 mini.
When configuring a DS18B20 sensor, the configuration webpage sometimes shows a sensor, sometimes not, sometimes it shows the correct bit-width selected, sometimes not...
It's a total mess each time i reaload the page.
When looking at the log-screen, i see that sometimes the values are not read.
Even more, when i additionally configure a controller that the ESPEasy should send the data to, or when i enable the Wifi indication LED.
Sensor is wired correctly (3-wire, pullup etc.)
Tried several modules, everywhere the same issue.
Anybody knows a solution?
DS18B20 configuration webpage issues
Re: DS18B20 configuration webpage issues
Yes, I recognize this.
But first:
Almost every day there is a new release. Be precise!
The symptoms look like a DS18B20 in parasite mode, that could be caused by a bad Vcc or Gnd connection.
Also make sure you have a strong pull-up (4.7K down to 2K in case of hairy wires).
Add a 4.7uF ElCo close to the connection point.
Try D5,D6 or D7, the known trouble-free GPIO's (D0 also in my setup).
And then ...
There are a number of reports with weak/bad voltage regulators:
See https://www.reddit.com/r/esp8266/commen ... r_on_your/
As the DS18B20 works on the 3.3.V side, it is an extra load to the voltage convertor.
You can try a 47uF ElCo on the 3.3V side to support the onboard capacitor.
Or use a separate 3.3. voltage convertor.
In total I bought 77 DS18B20 sensors from different shops.
Recently I have experienced a "bad" (?) batch of #5 DS18B20 from Ali supplier: Shop1280487 Store, that shop is gone now!
Later a good batch of #5 from http://www.aliexpress.com/store/1916536 ... 4c4dYjtXez
So you could have a bad batch!
I use this meter: https://nl.aliexpress.com/item/GM328-Mu ... Title=true to check the connections.
It shows 2 diodes from GND to VCC and Data.
In that way, I know that my wiring is correct.
Here also a report from an unexplained problem with DS18B20:
https://github.com/letscontrolit/ESPEasy/issues/1723
You could try a release of a long time ago.
ESPEasy_mega-20180323 is reported as more than 150 day stable.
(sorry, can not find a GitHub link)
For my production environment I use ESPEasy_v2.0.0-dev11 running all the time, with an automatic reboot before the 49day bug comes in!
But first:
the latest built is a forbidden word, .. useless text, ...without information.the latest built
And then ...
What GPIO ? Be precise!Wemos D1 mini
Neither useless, nor forbidden... actually totally simple - just look at the date of the posting.But first:
...the latest built is a forbidden word, .. useless text, ...without information.
All well and ofcourse no parasite mode with 12 sensors in a line.The symptoms look like a DS18B20 in parasite mode, that could be caused by a bad Vcc or Gnd connection.
EMI issues, brownouts or voltage stability issues definately no - always checking signal integirty with the scope.
Does definately not depend on GPIO.What GPIO ? Be precise!
Why should the web-interface show different sensor addresses in the task setting almost each time i reload the page if there was a hardware issue?
It's definately a software issue.
The entire plugin Dallas is broken since https://github.com/letscontrolit/ESPEas ... 6e4356031d.
Namely it provides stale data and violates the 1-wire bus.
Solution: use prior version
I didn't know that. Could you open a new issue on GitHub?BAnton wrote: ↑05 Dec 2018, 15:15 The entire plugin Dallas is broken since https://github.com/letscontrolit/ESPEas ... 6e4356031d.
I finally took a look at the "_P004_Dallas.ino" plugin code.
Found that the 1-wire communication part and timing is not optimal.
Especially if wires are a bit longer (my bus is 4 meters with 12 sensors) the existing code provocates unstable behaviour (as i described in the opening post).
I changed the code to be on the secure/conservative side in compliance with the timings in the datasheet.
Ofcourse it needs some more testing - but so far the issues have completely gone
Maybe somebody can check in parallel before i open a pull request?
