Can one Node be AP for other?
lolek481289
#1 Post by lolek481289 » 31 Dec 2018, 00:51
HI guys,
I'm facing small issue and I'm not sure if this is simply limiation of EspEasy or I'm doint sth wrong..
So (due to WiFi signal issues) I cannot connect 2 nodes via regular AP so I want to set one node as AP and another as STA - is that possible at all ?
  • I've tried to force AP mode implementing simple rule
    On System#Boot do
       WifiAPMode
but it start AP mode only for while and somehow connects as well to regular WiFi network which has been set-up there :shock:
  • thus I've tried to do workaroung by setting dummy name for SSID network - issue is that when I start configuring it (even simple things like name of Node) system becomes very unstable - hardly accesible, random reboots etc
Can someone advice how to overcome it ?
Is it possible that one Node will be AP for the other ?
thank you in advance for any comment
PS - I'm using latest release
lolek481289
Re: Can one Node be AP for other?
#2 Post by lolek481289 » 09 Jan 2019, 19:43
Hi guys- anyone facing same issue?
Any advice ?
Users browsing this forum: Bing [Bot] and 100 guests
