Compiler error with latest release.
EddyG
#1 Post by EddyG » 08 Jan 2019, 13:08
I am using Arduine IDE 1.8.8
The clean install of version "ESPEasy_mega-20181220" compiles fine. (And all previous versions did)
The clean install of version "ESPEasy_mega-20190108" gives errors.
The offending code is in ESPEasy-Globals.h
String getUnknownString();
and in "Misc.ino"
String getUnknownString() { return F("Unknown"); }
How can I solve that? If I uncomment one or the other I get other compile errors.
The compile errors started with the switch from "ESPEasySoftwareSerial" to "ESPEasySerial" because "ESPEasy_mega-20181231" complies fine too.
EddyG
Re: Compiler error with latest release.
#2 Post by EddyG » 08 Jan 2019, 17:49
The "static" in ESPEasy-Globals.h solved the error, but now I get other errors in the Arduino IDE.
_Plugin_Helper_serial:3:47: error: 'ESPeasySerialType' has not been declared
 static String serialHelper_getSerialTypeLabel(ESPeasySerialType::serialtype serType) {
_Plugin_Helper_serial:30:1: error: 'ESPeasySerialType' does not name a type
 ESPeasySerialType::serialtype serialHelper_getSerialType(struct EventStruct *event) {
C:\Users\Eddy\Documents\Arduino\ESPEasy\_Plugin_Helper_serial.ino: In function 'String serialHelper_getSerialTypeLabel(ESPeasySerialType::serialtype)':
_Plugin_Helper_serial:3:84: error: 'String serialHelper_getSerialTypeLabel(ESPeasySerialType::serialtype)' redeclared as different kind of symbol
_Plugin_Helper_serial:3:15: error: previous declaration of 'String serialHelper_getSerialTypeLabel'
C:\Users\Eddy\Documents\Arduino\ESPEasy\_Plugin_Helper_serial.ino: In function 'void serialHelper_webformLoad(EventStruct*)':
_Plugin_Helper_serial:49:55: error: no match for call to '(String) (ESPeasySerialType::serialtype&)'
       option = serialHelper_getSerialTypeLabel(serType);
Multiple libraries were found for "Servo.h"
 Used: C:\Users\Eddy\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\Servo
 Not used: C:\Program Files (x86)\Arduino\libraries\Servo
exit status 1
Hope that can be solved too.
#3 Post by grovkillen » 08 Jan 2019, 18:12
Have you downloaded today's code base? TD-er applied a fix...
EddyG
#4 Post by EddyG » 08 Jan 2019, 19:36
I saw on GitHub what the little change in "ESPEasy-Globals.h"was (static) and I applied that manually.
So the first error is gone, but I got other errors back. See above.
#5 Post by grovkillen » 08 Jan 2019, 20:04
Ok, we're officially using PlatformIO on Atom. Sorry for not being able to help more.
EddyG
#6 Post by EddyG » 08 Jan 2019, 21:17
Pitty, but I still hope that TD-er can solve this error too.
ltrpv
#7 Post by ltrpv » 09 Jan 2019, 00:59
I managed to work-around this issue by including the espeasyserial.h in the global.h, so it gets included sooner. Probably a dependency-loop somewhere.
EddyG
#8 Post by EddyG » 09 Jan 2019, 14:06
Could you tell where you included the ESPeasySerial.h
Because I included it but got other errors instead.
EddyG
#9 Post by EddyG » 09 Jan 2019, 14:22
Found it!
I include the ESPeasySerial.h at the end of my Custom.h
That did the trick.
pitrio
#10 Post by pitrio » 10 Jan 2019, 15:39
dear all,
I also have the same problem during compile Espeasy with Arduino IDE.
thank you in advance if you can solve it!
ricc
