I'm facing small issue and I'm not sure if this is simply limiation of EspEasy or I'm doint sth wrong..
So (due to WiFi signal issues) I cannot connect 2 nodes via regular AP so I want to set one node as AP and another as STA - is that possible at all ?
- I've tried to force AP mode implementing simple rule
On System#Boot do WifiAPMode endon
- thus I've tried to do workaroung by setting dummy name for SSID network - issue is that when I start configuring it (even simple things like name of Node) system becomes very unstable - hardly accesible, random reboots etc
Is it possible that one Node will be AP for the other ?
thank you in advance for any comment
PS - I'm using latest release
