Wiring & measure VCC with NodeMCU v3
Hi there, this is my first post so please be nice to me
- I own a NodeMCU v3 and flashed a _VCC build to it.
- I have a 18650 battery shield v3 with USB-A, 5V out and 3V out.
I want to use NodeMCU v3 with this "shield" and I really don't know how to wire this correctly (I guess 5V Shield to Vin NodeMCU would be correct?). So do I need additional wiring to measure VCC and get informed when battery is running low? Would be cool to hear from you.
EDIT2: Don't use 5V to VIN but 3V(Shield) to 3V(NodeMCU) for voltage measuring.
Edit: I connected 5V to VIN and get 2.99V on System Input VCC - is this correct?
Re: Wiring & measure VCC with NodeMCU v3
Sounds about right. The VCC reported via the Analog is what the ESP is "seeing" and the ESP is working on 3.3V.
Thanks for your fast reply grovkillen, but I didn't connect anything on A0 - so I don't know how this measurement comes from.grovkillen wrote: ↑14 Jan 2019, 11:59 Sounds about right. The VCC reported via the Analog is what the ESP is "seeing" and the ESP is working on 3.3V.
Its internally, I suspect you using the VCC bin file?
Yes, I'm using a recent _ESP8266_4096_VCC.bin - so this value should decline rapidly when battery starts to empty, right? So no information how much percentage or mAh left.
No you need to test yourself what levels are good and then you can use formulas to show percentage.
Ok, thank you very much!
Last question: For deep sleep mode I set up sleep time in config and connect D0/GPIO16 to RST and NodeMCU comes up periodically to send values?
Yes, but you might want to use rules to get the values sent more efficient.
Users browsing this forum: Ahrefs [Bot] and 31 guests
