Hey guys,
how can I send the serial commands received on the Rx-Pin to a UDP-port....? The other direction (send commands to ESPeasy) works fine
Would like to use it as a "Serial Wifi Bridge".
Kind regards,
P406
Ser2Net - send data to UDP
Re: Ser2Net - send data to UDP
Is there no way to send everything received to an UDP-port?
I had an Sketch for Arduino what did exactly this, but was only for DHCP... That's why I want to use ESPeasy.
Kind regards,
P406
Kind regards,
P406
Could you explain more exactly what you're wanting to accomplish?
Hi grovkillen,
I'm controlling my AV-Receiver that only supports RS232 commands. But he is also sending the state back on the Rx pin, when you change something (like volume f.e.) directly on the receiver. So I want to make ESPeasy a kind of "Serial Wifi Bridge" .
Kind regards,
P406
Kind regards,
P406
Now that sounds like a great idea. You need to look through the GitHub, I think I (myself) created a feature request on that topic. Add your vote (thumbs up) and a link to this topic in the.
The Transmit-Part is working perfectly! Just missing the possibility to get the state back....
Kind regards,
P406
Users browsing this forum: Bing [Bot], Google [Bot] and 108 guests
