wifi diconnect assoc exired Disconnected! Reason: 'Auth expire' Connected for 2247 ms
riker1
#1 Post by riker1 » 15 Apr 2018, 11:59
strangewise I am having a constant disconnects.
IFI : Disconnected! Reason: 'Auth expire' Connected for 2247 ms
wifi is ok. do not know where auth is expering?
Thanks for the hints.
t
Re: wifi diconnect IFI : Disconnected! Reason: 'Auth expire' Connected for 2247 ms
#2 Post by TD-er » 15 Apr 2018, 12:45
The reason of the disconnect is just a standard reason returned by the wifi layer.
Some are given by the accesspoint and some caused by the "user" like an intentional disconnect.
As far as I know, the "Auth expire" is something related to a expired session.
What ESP are you using? ESP8266 or ESP32?
I've seen it myself a few times, but not more than just a few times. Surely not every minute.
Could you test this build: https://www.dropbox.com/s/xxy65135tfcgy ... 5.rar?dl=0 ?
riker1
#3 Post by riker1 » 29 Jan 2019, 09:15
I am having the same issue with a new firmware
INIT : Booting version: mega-20190109 (ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
111 : INIT : Warm boot #2 - Restart Reason: Software/System restart
113 : FS   : Mounting...
138 : FS   : Mount successful, used 75802 bytes of 957314
480 : CRC  : program checksum       ...OK
517 : CRC  : SecuritySettings CRC   ...OK
624 : INIT : Free RAM:22672
626 : INIT : I2C
626 : INIT : SPI not enabled
639 : INFO : Plugins: 46 [Normal] (ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
642 : WIFI : Set WiFi to STA
674 : WIFI : Connecting TR7272 attempt #0
675 : IP   : Static IP : 192.168.0.149 GW: 192.168.0.31 SN: 255.255.240.0 DNS: 1.1.1.1
2012 : WD   : Uptime 0 ConnectFailures 0 FreeMem 21720
4633 : WIFI : Disconnected! Reason: '(2) Auth expire' Connected for 3857 ms
riker1
#4 Post by riker1 » 29 Jan 2019, 20:01
there is an new error message after I swapped to another SSID
Disconnected! Reason: '(4) Assoc expire' Connected for 4749 ms
riker1
#5 Post by riker1 » 29 Jan 2019, 20:03
TD-er wrote: 15 Apr 2018, 12:45 The reason of the disconnect is just a standard reason returned by the wifi layer.
it is a wemos D1 R1
alabama
#6 Post by alabama » 29 Jan 2019, 23:28
I fear I have the same problem since I updated to mega-20190121 some days ago. I made my first steps with use of MQTT and wondering about the very often publish from the first task even if ther happens nothing on the WeMos. But now I see in my accesspoint that the wifi connection breaks within sometimes less than 30 seconds.
