[SOLVED] Problems getting ESPEasy configured - unresponsive after reboot
dolittle
#1 Post by dolittle » 11 Feb 2019, 18:37
first of all I want to emphasize that I love the flexibility of ESPEasy and thank you guys for the great job.
Nevertheless I'm constantly experiencing problems when it comes to configuring my devices. The description of it is very simple.
1. flash the device
2. boot the device - most of the time I have to repower the device multiple times to show up in my mobile although I wait a minute or more until power cycle
3. enter the wifi credentials - This fails very often. Most of the time I end up in erasing the flash and starting at 1.
4. enter the config page and adjust the settings
5. reboot and very often the device gets stuck here. LEDs flash, but no open access point and no fetching of DHCP address. So back to 1.
6. sometimes it helps to import an old config.dat to survive the reboot
If I flash the very same device with tasmota. There's no such problems at all. But it doesn't have the flexibility.
I experienced this across all devices I flashed. Namely Sonoff Touch, Sonoff S20, H801. About 20 devices they all showed the same problem.
No difference if stock firmware image or self compiled.
Anyone any idea what I'm doing wrong or experiencing the same?
Re: Problems getting ESPEasy configured - unresponsive after reboot
#2 Post by grovkillen » 11 Feb 2019, 19:08
Thanks for the feedback. You shouldn't have these problems but you might want to try the ESP.Easy.Flasher.exe of you're on Windows. It will speed things up for you.
dolittle
#3 Post by dolittle » 11 Feb 2019, 19:14
Thanks for the fast reply.
I am happily using esptool under Linux without any flashing problems. It’s no problem to get the firmware in the flash memory. No problem with tasmota but with ESPEasy.
#4 Post by grovkillen » 11 Feb 2019, 19:19
Ok so please report everything on GitHub. Meanwhile: program the settings using serial commands.
kimot
#5 Post by kimot » 12 Feb 2019, 19:13
My way to program Sonoffs:
To check comunication:
esptool.py --port /dev/ttyUSB0 flash_id
Erase flash:
esptool.py --port /dev/ttyUSB0 erase_flash
Program ESPeasy bin:
esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash 0x00000 ESP_Easy_v2.0-20180322_normal_ESP8285_1024.bin
Repower Sonoff and connect to ESP in AP mode after a little delay.
Configure my home wifi SSID and password and let ESPeasy connect to my wifi.
But now I do not know IP assignet to ESPeasy by DHCP server of my router.
So open DHCP server leases tab end check which IP was assigned.
Write this IP to browser and on opened ESPeasy web page config new Static IP.
Reboot and use this new IP.
dolittle
#6 Post by dolittle » 12 Feb 2019, 19:51
Hi kimot,
that's exactly the way I do it.
esptool.py --port /dev/ttyUSB0 write_flash --flash_mode dout 0x0 latest_build.bin
The flash rate is not limited by me because there's a hash check if everything was written properly at the end of the process.
kimot wrote: 12 Feb 2019, 19:13 My way to program Sonoffs:
Erase flash:
kimot
#7 Post by kimot » 12 Feb 2019, 21:01
Try without --flash_mode DOUT , like me.
dolittle
#8 Post by dolittle » 22 Feb 2019, 07:50
OK,
sorry for the late reply. But now I sorted this out. The problem was in fact the DOUT parameter. I upgraded my 8266 devices from 1MB flash to 4MB flash and according to the platformio.ini file the firmware is flashed in DIO mode instead of DOUT. By omitting this parameter everything went fine.
Thanks for helping.
Users browsing this forum: No registered users and 87 guests
