Rules on mega version problem
kimot
#1 Post by kimot » 14 Mar 2019, 22:17
Can somebody check my rules, which not works on mega version firmware please.
I am normally using v2.0 version firmware for my floor heating controller.
Rules have got about 1900 characters and all works fine.
If I try new mega versions no "if" statements works.
I "strip" down this rules for testing and easy understood.
On System#Boot do
 gpio,13,0            // relay and LED off
 gpio,12,0
 TaskValueSet,2,2,27  // Var#Setpoint  27deg
 TaskValueSet,2,3,0   // Var#Heating
 TaskValueSet,2,4,20  // Var#Mode
 TaskValueSet,2,1,1   // Var#HDO
 TaskValueSet,4,1,0
 TaskValueSet,4,2,0
 TaskValueSet,3,1,24.5  //  Floor#Temp simulation to 24.5deg
 timerSet,1,30         // timer1 event after 30s
on HeatingOn do        // relay and LED on
 gpio,12,1
 gpio,13,0
on HeatingOff do      // relay and LED off
 gpio,12,0
 gpio,13,1
On Rules#Timer=1 do
 TaskValueSet,2,3,0              // clear Var#Heating
if [Floor#Temp]<[Var#Setpoint]
  TaskValueSet,2,3,1             // if heating needed, set Var#Heating to 1
if [Var#Heating]=1
  event,HeatingOn             // relay and LED on
  event,HeatingOff             // relay and LED off
 timerSet,1,60                  // next timer1 event after 60s
Dummy variable Floor#Temp simulates temperature from DS18B20 for this testing.
On v2.0 it works fine and debug is here ( commented by me ):
EVENT: Rules#Timer=1
ACT  : TaskValueSet,2,3,0
ACT  : TaskValueSet,2,3,1         // if [Floor#Temp]<[Var#Setpoint]    24.5<27
ACT  :
ACT  : event,HeatingOn         // if [Var#Heating]=1
EVENT: HeatingOn
ACT  : gpio,12,1
SW   : GPIO 12 Set to 1
ACT  : gpio,13,0
SW   : GPIO 13 Set to 0
EVENT: HeatingOn Processing time:69 milliSeconds
ACT  : timerSet,1,60
EVENT: Rules#Timer=1 Processing time:128 milliSeconds
for mega it do not work - no setting Var#Heating to 1
I see problems in "if" statements
31767 : EVENT: Rules#Timer=1
31800 : ACT  : TaskValueSet,2,3,0
31811 : Command: taskvalueset
31811 : TaskValueSet,2,3,0
31831 : Lev.1: [if 24.50<]=false               // if [Floor#Temp]<[Var#Setpoint]    24.5<27
31839 : ACT  :
31849 : Lev.1: [if =1]=false                        // if [Var#Heating]=1
31854 : Lev.1: [else]=true
31857 : ACT  : event,HeatingOff
31865 : Command: event
31866 : event,HeatingOff
31868 : EVENT: HeatingOff
31925 : ACT  : gpio,12,0
31930 : SW   : GPIO 12 Set to 0
31933 : ACT  : gpio,13,1
31937 : SW   : GPIO 13 Set to 1
31962 : EVENT: HeatingOff Processing time:94 milliSeconds
31967 : ACT  : timerSet,1,60
31974 : Command: timerset
31975 : timerSet,1,60
31992 : EVENT: Rules#Timer=1 Processing time:225 milliSeconds
If I change if [Floor#Temp]<[Var#Setpoint] to if [Floor#Temp]<27
this part of code works and sets Var#Heating to 1
But in real version I am sending Setpoint from Domoticz, so I need store it and compare from dummy variable.
31824 : Lev.1: [if 24.50<27]=true
31828 : ACT  : TaskValueSet,2,3,1
31839 : Command: taskvalueset
31839 : TaskValueSet,2,3,1
But if[Var#Heating]=1 still do not work correctly.
Thanks for your advice.
My Dummy variables:
Re: Rules on mega version problem
#2 Post by ThomasB » 15 Mar 2019, 01:24
I see two TaskValue variables in your rules that are referencing a missing Dummy Device. These:
 TaskValueSet,4,1,0
 TaskValueSet,4,2,0
Maybe this is confusing the rule engine? Try removing them (or create the mating Dummy Device and its 2 variables) and see what happens.
kimot
#3 Post by kimot » 15 Mar 2019, 23:12
I remove it, but result is the same.
I think - it is very simple rules and I do not understand why it not works on mega version.
#4 Post by ThomasB » 16 Mar 2019, 18:05
You have a odd problem. I don't see any other issues in the rule syntax. Maybe another set of eyes will spot something.
BTW, in Tools=>Advanced_Settings->Rule_Settings there is a entry for "Old Engine." This box should be checked (enable old engine).
Users browsing this forum: Google [Bot] and 111 guests
