Please help, my sr501+wemos keep loop "No motion" " Motion detected"
-----------MY OUTPUT---------------
01:58:20.564 -> Motion detected ALARM
01:58:22.576 -> No motion
01:58:28.582 -> Motion detected ALARM
01:58:30.586 -> No motion
01:58:36.559 -> Motion detected ALARM
01:58:39.576 -> No motion
01:58:44.595 -> Motion detected ALARM
01:58:47.575 -> No motion
01:58:58.584 -> Motion detected ALARM
01:59:01.602 -> No motion
01:59:15.587 -> Motion detected ALARM
01:59:17.589 -> No motion
01:59:23.587 -> Motion detected ALARM
01:59:26.607 -> No motion
01:59:32.613 -> Motion detected ALARM
01:59:35.602 -> No motion
-----------MY OUTPUT end ---------------
---------------------------------Orginal code from internet:------------------------------------------
// Author: Vishal Pal Chaudhary
// Bitbucket: https://bitbucket.org/vishix
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
const char* ssid = "Your SSID";
const char* password = "Your password";
#define mqtt_server "MQTT Server hostname / IP"
const int mqtt_port = 1883;
#define mqtt_user "MQTT Username"
#define mqtt_password "MQTT Password"
#define sensor_name "Your_sensor_name" //Must be unique (Fall back already handled with chip id)- Vishal
int pirPin = D6; // Put the data pin number where u connected the pir sensor. D6 in my case
int val;
int state = 0;
String wemos_hostname;
String mqtt_state_topic;
String mqtt_availability_topic;
String mqtt_config_topic;
WiFiClient espClient;
PubSubClient client(espClient);
void setup()
Serial.begin(115200);
// OTA CODE //
Serial.println("Booting");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
wemos_hostname = sensor_name "-" + String(ESP.getChipId(), HEX);
ArduinoOTA.setHostname(String(wemos_hostname).c_str());
ArduinoOTA.onStart([]() {
Serial.println("Start");
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println("Ready");
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
// OTA CODE //
mqtt_config_topic="homeassistant/binary_sensor/" sensor_name "/config";
mqtt_state_topic="homeassistant/binary_sensor/" sensor_name "/state";
mqtt_availability_topic="homeassistant/binary_sensor/" sensor_name;
//wemos_hostname += String(ESP.getChipId(), HEX);
Serial.println("hostname="+wemos_hostname);
pinMode(LED_BUILTIN, OUTPUT);
// delay(5000);
Serial.println();
// WiFi.printDiag(Serial);
client.setServer(mqtt_server, mqtt_port);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
// If you do not want to use a username and password, change next line to
// if (client.connect("ESP8266Client")) {
char will_message [] = "offline";
if (client.connect(String(wemos_hostname).c_str(), mqtt_user, mqtt_password,String(mqtt_availability_topic).c_str(),0,1,will_message)) {
client.publish(String(mqtt_config_topic).c_str(), String("{\"name\":\"" sensor_name "\", \"device_class\": \"motion\"}").c_str(), true); //Autodiscovery packet sent with retained flag.
client.publish(String(mqtt_availability_topic).c_str(), String("online").c_str(), true);
Serial.println("connected");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void publish_message(int state){
//Serial.println("/home/" sensor_name "/motion");
if(state)
client.publish(String(mqtt_state_topic).c_str(), String("ON").c_str(), true);
client.publish(String(mqtt_state_topic).c_str(), String("OFF").c_str(), true);
void loop()
ArduinoOTA.handle();
if (!client.connected()) {
reconnect();
client.loop();
val = digitalRead(pirPin);
//low = no motion, high = motion
if (val == LOW)
//Serial.println(state);
if(state == 1)
state = 0;
publish_message(state);
//client.publish("/home/"+sensor_name+"/motion", String(state).c_str(), true);
Serial.println("No motion");
pinMode(LED_BUILTIN, 0);
if(state == 0)
state = 1;
Serial.println("Motion detected ALARM");
pinMode(LED_BUILTIN, 1);
delay(1);
Please help, my sr501+wemos keep loop "No motion"" Motion detected"
Re: Please help, my sr501+wemos keep loop "No motion"" Motion detected"
1. Set the SR501 jumper to REPEAT TRIGGER, re-apply power, and try again. If necessary, reduce sensitivity to minimize false detection. Be sure to power it with 5V (not 3.3V).
2. This forum is specifically for ESPEasy controlled hardware. So for additional help on your ESP8266 device I recommend contacting the author of the code you are using.
Users browsing this forum: No registered users and 26 guests
